big ass alternator?
strvger
19
the land of 2 seasons-Winter and getting ready for
2.3
ive had the GM 1 wire conversion for almost 5yrs. It was ALMOST a direct bolt onto my 2.8 bracket. I just had to use washers for some spacers on the bottom pivot hole, and all i did was run the wire from the alternator to the starter solenoid.
need to know which gm alternator you used. thanks.
NMB2
July 2010 OTOTM Winner
22
Cody, WY
5.0 V8
ummmm I really dont know. I just walked into a napa and asked them for a 100+amp GM-1wire and he knew exactly what i was looking for. Ill find a part number off of it tomorrow for you if you cant find what you need. sorry i couldnt be more help.
motaaa
here is the alternator
this is what you do with the wire.
vwa-la, you have power.
Hope this helps you!
ah, it all makes sense now..
what king of GM vehicle will i find this alternator in? year? make?
NMB2
22
Cody, WY
5.0 V8
im pretty sure its a 70s and 80s GM truck. It definitly isnt newer. Again, I will find the number on it today, I have to go to work now but when I get home tonight I'll see if i cant check for you.:icon_thumby:
martin
26
St Bruno, Quebec
1991
83 Olds Ciera, 84 buick Century or any of the gm variants with the 2.8 v6. You might have to change the pulley as some of them had a multi-v pulley but that should not be much of a problem.
holyford86
Some guy with a problem
619
Plattsburgh, NY
many
33x12.50R15
I used a 130 amp 3.0 Taurus alternator, I had to swap it to a V belt pulley, it required a little bit of machining which would probably cost under 20 bucks if you had to pay someone to do it. I also had to make a little conversion bracket to get it to bolt into the slotted adjustment bracket on the 2.9. I had no issues with it in the 130 amp configuration and recently had it rebuilt to 200 amps, the only complaint I have with it is the belt life is not that great, I can get about a year out of a good belt.
dusto2
scv ca
2.9
i did what holyford did its real easy to do it, i didnt have to machine the pulley though found one that worked fine for the v belt, and for the bracket i used a chevy 350 bracket re drilled at the bottom and bent to match the factory one and it worked perfect i can post pics later if ya want
motaaa
well then it looks like im heading to the junkyard tomorrow to see what i can dig up :D
holyford86
619
Plattsburgh, NY
many
33x12.50R15
The bracket I made
motaaa
The bracket I made
for some reason my bracket is longer, i guess on your engine that ear thing on the alt had to be at 2 oclock but my factory alt had it top center like that picture :icon_confused:
