youngbuckwithapickuptruck
- Oct 7, 2021
- 37
- california
- xl
- Engine Type
- 2.5 (4 Cylinder)
- 2WD / 4WD
- 2WD
- Tire Size
- stock
I replaced my 'rear differential gear oil' a year ago.
I recently noticed my 'rear differential gear cover' was leaking.... some bolts were loose and i just snugged them up.
I popped open the 'fill plug' to top off my gear oil and noticed these two large chunks of metal. is my 'rear differential' going to grenade itself soon? the 'differential gear' was low about 125cc of 'differential gear fluid' I believe it uses about 1500cc of 'gear oil'.
I suppose I could pop off the plug every week to see if anything else starts shredding off. I am also planning on replacing my leaf springs. maybe it is time for a new rear axle as well /facepalm
I noticed most of the rear axles at pick-n-pull have the rear differential exposed. to the workers just pop the cover off to drain fluids and throw it to the side?
would unskilled engine braking contribute to the damage?
