Bronco 2.9 Starter problems
d9n
Allendale, MI
thanks about the plate info. I do have that so that's a relief I'm not missing a spacer.
Tonight I put a new starter on it and starts better then before (no high pitch grinding sound). I'll give it a year and see what happens.
While under the truck I chased the ground cables, one runs from the battery to the eng block and another runs from the eng block to the frame. Consistance building on the Ford line at it's best.
2813josh
9
Mascotte,FL
Ford,Ford
4.0 V6,4.0
No problem. Well this things been rigged pretty bad soo... and I got a new starter to go on...hope this works
IMenriched
4
NE Iowa John Deere country
02'
2.9 & 5.4
Gents
what you maybe experiencing is poor workmanship/quality on rebuilt starters....hence why auto parts stores offer different levels....rebuilt 1yr warranty ...limited lifetime....and forever and of course new life time warranty.
not to say the poor battery cables didn't aid the life expectancy situation...so you can spend a little or a lot....just don't be surprised when economical replacement parts fail early...the old addage you get what you pay for...and keep the receipt
d9n
Allendale, MI
yes, I agree with you that you get what you pay for.
1st starter came with truck, no idea what it was but it last 6 months. Starter #2 I bought, life time warranty, lasted two weeks.
Starter # 3 exchange unit and lasted just over a year.
Starter #4 I just bought, one year warranty and makes the least amount of noise of all I've had on the truck. Makes no sense.
One thing I was wondering last night as I put it on, I have headers that are about 1-1/2 to 2 inches away. Would you think the headers are making enough heat to effect the starter?
By the way, thanks Josh.
IMenriched
4
02'
2.9 & 5.4
it would seem that there is enough room....but might not hurt to rig a heat shield up of some kind...considering the amount of starter issues you've had.
2813josh
9
Mascotte,FL
Ford,Ford
4.0 V6,4.0
ok got the new lifetime starter. Plate wasn't sitting flush with the trans so I got out my bfh...Starter in and it cranks! most of the time< sometimes seems like it's binding. Started up, ran for about 15 sec..and now it won't start! Ahh!
2813josh
9
Mascotte,FL
Ford,Ford
4.0 V6,4.0
Oh and your welcome..I think it could be an alignment issue..Check that plate really close. I think that's what gives the most problems...just a guess tho
2813josh
9
Mascotte,FL
Ford,Ford
4.0 V6,4.0
:bawling:This one lasted a few days and now it just spins....
Dont know what to do:icon_confused:
loneranger48
Washington
2.9L of FUry!
is your flywheel intact and in good conidition?
DisturbedMXer8
29
Anaheim, California
Ford Ranger XLT
Yeah man, at this point I'd look into checking that flywheel/flex plate. It could be missing some teeth or be bent, or possibly even loose.
2813josh
9
Mascotte,FL
Ford,Ford
4.0 V6,4.0
idk the teeth all look fine i dnt get it. I'm replacig the solenoid and cables and another starter to see what happens now...The flywheel doesn't feel loose and if it as bent I'd have a bad vibration when running, right?
holyford86
Some guy with a problem
630
Plattsburgh, NY
many
33x12.50R15
check the bolts holding the engine to the transmission, I have had a transmission try to remove itself before and it was doing the sort of thing that you describe.
2813josh
9
Mascotte,FL
Ford,Ford
4.0 V6,4.0
I'll double check that. Thanks
Arlo
Same problem with my 1989 Bronco II. Started grinding after clutch was replaced. New starter latest for about 5 starts then started grinding. I loosened starter mounting bolts and shoved starter closer to flywheel (Lot of slop in mounting bolts) and started working, for about 3 grind free starts. I suspect the mechanic did not use the correct mounting bolts when starter put back in. Since then I had an idiot run a stop sign and destroy the BII front end which I am currently rebuilding. But am currently thinking of the best way to hold that starter tight agains flywheel. Aluminum bellhousing and cheap metal in mounting tabs on starter doesn't help. But I am sure it is a mechanical proximity to flywheel problem. It is a standard and I always parked on a hill to start it.
1986fordranger
central VT
2.3l/4.0l
the best way is just replace the trans with a newer mazda M50D transmission with the integral bell housing, these mitsu 145 and 146's and the TK 5's tend to give a lot of problems, or you can get bolts with a larger shoulder on them to actually fit the mounting ear's in the starter, also I remember another member here stating that he used a small piece of sheet metal jammed between the outer section of the bell housing and the starter to help hold the start toward the flywheel
