Bronco II No Spark
Herold417
Post falls Idaho
2.8L dura spark/ 2.9L
Im at ends with my bronco right now ive replaced everything and still have no spark coming out of the coil. I have power to the coil but when the engine is turning over no spark comes out. Things i have replaced;
Ignition coil
pickup coil
ignition control module tried two computers
ignition switch
after all of this still no spark. Need help!!
Cam10
Ponoka, Alberta, Canada
2.9 EFI
Are you still trying to fix your bronco? if so, when you said "no spark comes out," are you referring to a lack of spark at your plugs?
Mr88ranger
You should have a module on the back of the distributor
That you can remove and take to an autoparts store and have tested (for free)
It took me awhile to conclude that that was my no spark problem.
I had power to the coil but would drop when turned over.
Hope this helps
The part cost me 40 so not to bad, just took forever to troubleshoot to that part with no help haha
6
New Orleans
'98
'94
'98
For
2.5, 2.3 & 3.0
Trying to be a better Christian than non-christians.
Check for saved codes.
Might be the Crankshaft Position Sensor or Camshaft Position Sensor depending on the year.
FloridaGrown
4.0 v6
What about the cylinder next to the coil. Done quote me the resistor I believe. That could be the culprit also.
MagicMexican
Have you tried the relays? If you follow the wires from the battery, there are a few relays on the passender side fender there. On my old bronco they had some fault. I would just wiggle them around until I heard a click and it would start right up.
Canndspam
SE Ohio
2.9L V6
I second checking the relays. I had a similar problem, replaced nearly the entire ignition system, wound up being the computer power relay. If i recall correctly its the brown one. Green is fuel pump, black is a/c. Someone please correct me if im wrong.
