- Jul 14, 2022
- 2
- Prescott, AZ
- Ford Ranger
- Engine Type
- V8
- 2WD / 4WD
- 2WD
Hello All,
I have seen a few posts on here talking about plumbing fuel lines for carburetors in V8 swaps. Most recommend using a return style fuel regulator, how necessary is this return line. What is its purpose?
I already have a MR. GASKET 9710 regulator with no return, is this workable. Is it possible to somehow add a return line with a T fitting, seems like that is how alot of the vapor lock fuel filters are built. However, it seems like the fluid would take the path of least resistance and just avoid the carb then.
Finally, the tank has quick connect fittings on a harder type of fuel line, how do I properly adapt this to my regulator anyhow. Do I splice it and use a fuel line fitting to change tubing types so I can use the softer lines to fit over my regulator's barbs? (I have no knowledge on anything fuel related so I am looking for the safe way to do it)
The vehicle is a 2wd 1987 Ford Ranger with a Ford 302
Thanks
Thanks
