Cast aluminum diff cover
17,931
SW Iowa
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
I didn't see where it said it wouldn't fit a 31 spline...
28 spline 8.8" axles have the diff cover face approx ¼ inch closer to the axle centerline than 31 spline, which has resulted in an occasional case where a cover wouldn't fit because it wasn't deep enough to clear the ring gear, but going the other way 'round (28 spl cover on a 31) I don't see an issue.
If worse got to worse, go snag one off the rear of a 2002-2010 Explorer. Pretty much is the same cover but with two IRS mounting "wings" on it that you can cut off easily.
Edit:
I see in the reviews section someone mentions having to grind off a rib that was hitting the ABS tone ring on their F-150... So seems if there's anything needed to fit it, it should be minor.
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
I think I can answer this one!
So yeah, you'll need to grind just a hair off one fin to fit the ABS tone ring should you need to use it. This axle is a 31 spline Explorer axle. This is my axle off my truck after I put the ARB in.
Kinda wish I was able to buy mine for that price...
17,931
SW Iowa
Edit:
I have checked into the Explorer one, you about have to pull the rear diff out of the car to get the cover. Just not that appealing in a JY setting.
Thanks!
I was under my truck and notice my stock stamped one is still oozing. Not really leaking just moist around the edges. The thing is glued on and I have done it twice now, I was looking for a "Solid" cover because I knew they were decent and fairly cheap when I came across this one which was cheaper yet and an actual Ford product. Bonus is saying I have a GT-500 part on my Ranger. :icon_hornsup:
I don't use the tone ring but I don't want to tear the axle apart to delete the tone ring.
Captain Ledd
39
Michigan
302, 2.3
I'm running 4.56 gears with 235/75R15's, I just wanted something that would dissipate heat better. Zero complaints about the cover.
17,931
SW Iowa
Ever measured the difference?
I just have 3.73's and 31's, never really worried much about heat but it probably won't hurt anything to run a little cooler. I think I saw somewhere it holds a little more fluid too.
I did find this one that came with the "correct" bolts. Basically a little over $2 a bolt which isn't horrible because they are kind of a special bolt (not just a generic cap screw)
https://www.amazon.com/gp/product/B01C69GMTU/ref=ox_sc_act_title_2?smid=A3MA0GVAOHQZNN&psc=1
CJ Pony Parts is over $200 for it.
Captain Ledd
39
Michigan
302, 2.3
I think I just used regular bolts? And I've never measured the difference. But I actually do haul a lot and I figured there'd be a lot more input RPM. Figured this would be the best option for a reasonable cost/effort. Looks better than the plastic one that was on it too.
17,931
SW Iowa
I haven't looked too hard into it yet, how did you plug the temp sensor hole? Is it pipe thread or some kind of o-ring seal against the flat face around the hole? Every other hole came with a plug in it but that one.
Captain Ledd
39
Michigan
302, 2.3
You know, I don't really remember, it was years ago. I think it was just a regular bolt? It sucks that I can't remember a whole lot when I did it, but how memorable is installing a diff cover several years ago that I haven't messed with since? The truck is at my parents place and I'm heading home the 14th/15th, not sure if you want to wait that long.
17,931
SW Iowa
No biggie, I can play with it some. Just wondering if you knew offhand :icon_thumby:
ericbphoto
Overlander in development
16,669
Wellford, SC
6"
If it's for a sensor, I'm sure it's parallel threads. If you know the manufacturer, you could ask them for the info.
This message composed solely of recycled electrons. Go green!
17,931
SW Iowa
It’s the factory cover for a 13-14 Shelby GT-500 with the track pack.
I need to get a moment to see what the sensor looks like.
ericbphoto
16,669
Wellford, SC
6"
according to this page Click Me
the threads are M10 x 1.6 -6h. I believe the "-6h" is just a tolerance and 6h is general tolerance so you can ignore it. Best solution is to find an M10 x 1.6 plug with sealing washer like This One.
Captain Ledd
39
Michigan
302, 2.3
I think that may be M10x1.5, I'm not aware of a 1.6 thread pitch. Likely just a typo on the page, 6 being right next to 5, but just for clarification sake.
Also I checked the date I put some of those pics on Facebook, it was about 5 1/2 years ago I put the cover on.
ericbphoto
16,669
Wellford, SC
6"
That's quite probable. I didn't have time to cross-check everything. Just trying to help get him headed in the right direction. It took less than 2 minutes on Google to get that far.
