Is he ASE? If he doesn't know what that means your in trouble. They should have ground the valves at the very least if they were leaking. It might have needed new valves? or seats? guides? That should have been cked if the heads were pulled. Not just "cleaned up"
Valve guides are small holes machined through the cylinder head for the valves. The valves fit into and slide in these guides.
Valve seats are round, machined surfaces in the combustion chamber port openings. When a valve is closed, it seals against the valve seat.
The compression gauge reading for a good cylinder will increase evenly to specifications. The gauge readings should not vary by more than about 10% from one cylinder to another.
Look for cylinder pressure variation during an engine compression check. If some cylinders have normal pressure and one or two have low readings, engine performance will be reduced. The engine will idle roughly and lack power. If all the cylinders have low compression readings (worn timing chain for example), the engine may run smoothly but lack power and get poor gas mileage. If two adjacent cylinders read low, the engine may have a blown head gasket between the two cylinders. A blown head gasket will sometimes produce a louder than normal puffing noise from the spark plug, injector, or glow plug holes with the gauge removed.
Low engine compression can be caused by:
Burned valve—valve face damaged by combustion heat.
Burned valve seat—cylinder head seat damaged by combustion.
Physical engine damage—hole in piston, broken valve, etc.
Blown head gasket—head gasket ruptured.
Worn rings or cylinders—part wear prevents ring-to-cylinder seal.
Valve train troubles—valves adjusted with insufficient clearance (keeps them from fully closing), broken valve springs, etc.
Jumped timing chain or belt—loose or worn chain or belt has jumped over teeth, upsetting valve timing.
Gasoline engine compression readings should be 125–175 psi (860–1200 kPa). Generally, the compression pressure should not vary more than 15–20 psi (100–140 kPa) from the highest to the lowest cylinder. Readings must be within 10% to 15% of each other.
