Cycle rack in the dumpster
Fabi1
50
Vitré France
Ford Ranger 4x2
Something I did with my ranger to attach my dirtbike involved a 2x12 board and one of those tire stands like pictured.
The stand was screwed into the board. The edges of the board were cut in the shape of a peg to fit into the bed (dumpster :) ) liner securely. Straps held the bike to the tie-down locations in the bed corners. Bicycles are a bit smaller and you may be able to fit several. I will search for a pic of mine.
Great thank you for this clarification, it ties in with my project, looking forward to seeing it
Fabi1
50
Vitré France
Ford Ranger 4x2
Do you know this anchor?
What do you think about this?
superj
2,578
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
before i got that innova rack, i made a rack using plywood, a 4x4, and the fork mounts bolted to the 4x4. i cut the plywood to fit the shape of the bed and just slide it in place and would mount the bikes. i used a ractchet strap across the top tube to keep the bikes in place but they never slide around on the plywood mount because it fit the bed floor shape. i just strapped them in because i was scared they would fly out in an emergency maneuver.
superj
2,578
ranger edge
none
none
235s
those actually can work very well but they are higher up. alot of people use those on trucks around here, though not for bicycle tie down points. you could easily use them though. they also make those anchors that mount in the bed wall stake holes but can be pushed down to hide when not in use. they are pop up anchors
Fabi1
50
Vitré France
Ford Ranger 4x2
Yes that's right, I saw this during my research, but I don't know if it will be adaptable in the holes of rangers from 1993, because I have sometimes seen from 1995 on certain pop-up models. But it's very interesting, although once again there is nothing in France, so I'm looking at you, if you have sites or specific references, I'm interested, thanks in advance for the time spent to answer me
superj
2,578
ranger edge
none
none
235s
Single Elevate Pickup Pop-Up Anchor Tie-Down | Discount Ramps
These easy-to-access anchor points make using tie-down straps in your truck bed a snap. The pop-up anchors fit into standard size pickup truck stake pockets and only need a Philips screwdriver for installation. The Bull Ring style anchor is perfect for quickly attaching S-hook and snap-hook tie-downs and folds down and out of the way when not in use. Each stake pocket tie-down features a 1/8" thick rubber seal to help prevent moisture and debris from entering the pocket, and to protect the bed rail surface. Fits standard pickup truck stake pockets using a 2-1/8" square anchor plate that pinches on the stake pocket lip when tightened. Also available in multi-packs.
  • Single pickup truck pop-up anchor
  • Manufactured from durable steel
  • 400 lbs. working load limit
  • 1,200 lbs. break strength
  • Fits into standard size (2-1/8" square) pickup truck stake pockets
  • Installs quickly using only a screwdriver
  • Bull Ring folds down into recessed area when not in use
this one gives you the hole size so you can measure your truck bed stake holes and see if they are the same
Fabi1
50
Vitré France
Ford Ranger 4x2
There you go, I made up my mind, I bought the anchors indicated, they seem interesting for this price, thanks again for the link. Now, they will be delivered to my friend in California who sees all my packages piling up and who will send them to me by container once they are all grouped together.
I will have to be patient...
Besides, on this same site, I almost let myself be tempted by another article, a bicycle support for bed...unfortunately too wide for the Ranger...that's exactly the idea of what I wanted to do, and there were no holes to drill or even welding to do, it holds by pressure inside the bed, too bad it was on sale
