Cyclical revving at idle
traildog
11
Missoula, Montana
Ranger FX4
Been awhile since I was on this forum, but looking for some diagnostic help. My 4.0 has developed an idle problem, which I assumed to be a vacuum leak as it's had a few of those in the past. But the carb cleaner/propane test doesn't bump up the rpms and if I disconnect the IAC it dies immediately. I replaced the IAC for good measure to no avail.
This morning it was doing something interesting- idling at 2000 rpm, then every 5 seconds it would rev up to 2500 for a few seconds and then come back down. No input to gas pedal during this. It kept in this pattern for minutes so I took a video:
I guess next on the list is to clean the throttle body and MAF sensor. But maybe the cyclical revving indicates something in particular?
Appreciate any help.
rusty ol ranger
2.9 Mafia-Don
7,502
Michigan
177 CID
No check engine?
Id bet on a TPS
traildog
11
Missoula, Montana
Ranger FX4
Hey I think that worked! Replaced the TPS and cleaned the MAF after work. Initially no change but after a cross town drive it seems the ECU adjusted parameters and it's running normal. Fingers crossed it holds. Thanks!
No members online now.
