Death wobble
Holsenback
Kentuckcy
4.0 SOHC
I have a 2003 FX4 Level II. I just got new BFG AT TA/ko's, and installed new lower ball joints, uppers were ok. I now have a severe wobble in the wheel. I've had the tires balanced 2 time and aligned 2 times.
Any ideas?
kennykenny
4
Manahawkin, NJ
Wheel bearing assembly with give you a nasty death wobble, check them.
Holsenback
Kentuckcy
4.0 SOHC
I'm also feeling vibration in the brake pedal along with a squeak when I slightly depress the pedal.
wrecking-crew
25
dirty jersey
06 chevy
88 ranger
6 cylinders
Sounds like a wheel hub is worn out and possibly wore the brakes . Check those.
Mrnicks
99" Ranger 4.0L
What was the conclusion to this? I have a similar problem.
Mrnicks
99" Ranger 4.0L
Try to bleed your steering system. That was my problem. With the truck running and the front end off the ground I turned the wheel almost lock to lock about twenty times. Most of the shake went away after that. Then after driving it for a few days it's all gone.
Hope this helps. Maybe it does maybe not. It really through me for a loop when I discovered to be my problem.
No members online now.
