do '92-'96 F150 8.8 have tone rings & sensor?
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
brainstorming & dreaming again.
I'm looking for a rear axle that's 5 x 5.5 and has ABS/speed sensor.
anything newer won't have 5x5.5 from what I've read.
thanks
franklin2
1,758
Virginia
Here's what rear axles where available in 1992. Looks like Canada did not have them.
ABS, 2.73 ratio
ABS, 3.08 ratio
ABS, 3.55 ratio
ABS, 4.10 ratio
w/o ABS; (Canada market), 2.73 ratio
w/o ABS; (Canada market), 3.08 ratio
w/o ABS; (Canada market), 3.55 ratio
w/o ABS; (Canada market), 4.10 ratio
Here's what rear axles where available in 1996. Looks like Canada still did not have it.
ABS, 2.73 ratio
ABS, 3.08 ratio
ABS, 3.31 ratio
ABS, 3.55 ratio
w/o ABS; (Canada market), 3.31 ratio
I believe you are correct, they went to metric in 1997 except the f250hd/350 which stayed the same till 1999.
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Rangers and RBVs never came with 5X5.5, only 5X4.5 until the T6 came out and went to 6 lugs.
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
With or without ABS it should have a tone ring '94 or newer I suspect or was it '92? Whenever they went to the electric speedo, my F350 is driven off the rear axle tone ring...
rusty ol ranger
2.9 Mafia-Don
7,503
Michigan
177 CID
92 went to the electronic speedo
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
true, but........ it's time for a change :icon_thumby:
I have 2-1/2 Rangers, lots of tools, and being retired have plenty of time ( I hope ).
even more noteworthy, the wiffie is retiring and I need something to get me outta da house :icon_rofl:
besides, the 8.8 with 5 x 5.5 will also fit the '78 Bronco that I may someday rebuild.
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
ABS, 2.73 ratio
ABS, 3.08 ratio
ABS, 3.55 ratio
ABS, 4.10 ratio
ABS, 2.73 ratio
ABS, 3.08 ratio
ABS, 3.31 ratio
ABS, 3.55 ratio
yep, I saw that on Car-Part too.
E150 stayed 5x5.5 for a while longer, but they are wider and have more diff offset.
Roert42
4,961
Kintersville, PA
Ranger XLT
4.0 SOHC
My 92 F150 8.8 had the tone ring on the carrier and the sensor in the pumpkin. If that’s what your asking.
