Door Adjar Switch
Blueox
13
Winona, MN
4.0 SOHC
Does the door adjar signal result from an open circuit or closed circuit. Asking cause it is rusted and not easy to replace. I could just tie the wires together and call it good.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,545
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I believe when door ajar switches moved into the latch assembly... the switch is normally open with the door closed. Provides a switched ground when the door opens.
At least it works that way on my 06.
