easy way to change the radius arm bushings
1991fordranger
what is the easiest way to change the radius arm bushings on my 91 4x4 ranger?
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
Remove 1-1/8" nut on the end of the radius arm. Cut the rivets out (should be two or three per side if they've never been changed) and remove the 4 bolts still holding the hanger on. Remove hanger. Replace bushings and bolt it back together.
rangerbum
30
Kalispell, Montana
2.8l
You could remove the rad arm brackets if they have been replaced in the past, if they are the originals they will be riveted on, I replaced my bent to crap and cracked brackets with the bushings at the same time since both needed it. But other than that, the bushings aren't fun to get at.
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
The EASIEST way is to drop it off at a local shop, say "replace these", and pick it up when its done.
The quickest way I've found is to remove the nut off the arm and the pivot bolt from the beam (leave the shock, spring, brakes, sway bar, etc attached). Pull the whole assembly forward about 2 inches, replace the bushing and reinstall everything.
alwaysFlOoReD
5,097
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
^^^ I didn't remove pivot bolt, and used a 2" ratchet strap to pull the beam forward enough to drop the arms out.
Richard
snoranger
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Richard
I do that on the drivers side, but the pass side doesnt always move enough to do it that way.
17,851
SW Iowa
Richard
I tried that with a come-along... and quickly quit when I saw the truck was trying to roll off the jackstand. I had it tied to a tractor infront of it and it might of worked if I had another tractor that moved handy to tie it to from behind but that is a lot of force to put the front end through. I was sliding the rear tires with it as it was...
I ended up cutting an X into the head of the rivets with a cutoff wheel and zipped them off with an air chisel which went very slick.
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
You dont need to have it on jackstands at all.
Destroyer000
January 2009 STOTM Winner
MTOTM Winner
8
Plattsburgh, NY
1999
4.0. 4.0 Supercharged
we just did this to my buddies truck. jacked up on the frame right behind the mount. enough to were the tires is on the ground still.. take a ratchet strap and we tied it off to his front bumper... custom bumper.. and it pulled it forward enough to get the radius arm out. just make sure you disconnect your sway bar
17,851
SW Iowa
Since the truck was sliding ahead and the RA wasn't coming out of the bracket it doesn't really matter much. I don't see how I could get an impact on the swaybar bolts with the wheel in place.
IIRC I had the spring and shock out for replacement already so it was just a limp beam sitting on a floorjack, I was killing a bunch of birds while I was there.
heptofite
62
2.3 EcoBoost
I find that it's best to use rubber bushings and not poly, the poly is too stiff and ends up trashing the brackets.
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
I ground the rivets off and removed the radius arm brackets. Replace the rivets with grade 8 bolts.
1991fordranger
What do the big nuts on the back of the ra torque to??
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
Til they're tight. Then tighten them a little further. They're supposed to be steel lock nuts.
92NHranger
New Hampshire
I just jacked my frame took off the bottom shock bolt loosened the coil nut spun it out and moved it forward. it takes some pressure but it works good.
