Electrical system issue 2001 Mazda B3000
Bob Rindy
4
La Conner, WA 98257
Mazda B3000 4x4
Neither the windshield wipers nor the radio work on my 2001 Mazda B3000 3.0l truck.
All relay's check fine with a relay tester. Wiper fuse is OK.
Is there anything common between the wipers and radio ??
franklin2
1,758
Virginia
Do you have a cheap radio that you use the front buttons? Or did they have a fancier radio with the buttons on the steering wheel. The wipers go through the GEM module. Just wondering if the fancier radios went through the GEM module also, or had a remote powered module my diagram is not showing.
Colin
182
ON Canada
Mazda
Did you just get the truck and its like this?
Or did this just happen?
Stock or aftermarket radio?
Wipers is probably the multifunction switch if the relays are good
Bob Rindy
4
La Conner, WA 98257
Mazda B3000 4x4
The radio is an after-market that was added later.
I know the wipers go thru the GEM, but not sure about the radio...
8,370
GEM is not connected to Radio wiring
Does the Washer work?
Same fuse as wipers, #16, 30amp in cab fuse box
Most common reason for wipers to not work is the Multi-Function switch(turn signal stalk), they wear out
2001 Radio wiring here: https://www.therangerstation.com/tech_library/pdf_documents/2001_Ranger_Radio_Wiring.pdf
Fuse 28 ONLY MUTES the radio when starting engine
Fuse 29 keeps the clock and preset memory, doesn't power the radio
Fuse 20 powers the radio if key is on PLUS it powers part of the GEM
So only connection there is
Fuse 11 also powers part of the GEM
These are all cab box fuses
