Bunger317
- Jan 3, 2023
- 6
- California
- Ford Ranger
Got a problem that's driving me nuts. Got a 1994 4.0 w/a4ld. Runs great. Gets shit mileage but I'm on 33s with 3.73s. Anyways I'm in so cal and it's been hot. 100-105° ambient. Since it got hot whenever I run my ac the water temp starts climbing. Gets up towards the A or L in normal. I shut the ac off and it starts cooling back down after a few minutes. So far I've replaced water pump. Thermostat(tried a 197 and 180). new radiator. Fan clutch seems to work fine. When it gets hot I can hear the fan roaring when I leave a stop sign. Flushed out the heater core with the hose. Ran a combustion gas test on the radiator to rule out head gasket. I've got a 180 stat in it now and it runs down toward the N until I turn the ac on and sit at a light then it starts climbing. With the 197 stat with my infared thermometer I was seeing as hot as 225 on the t stat housing and 205-210 on the upper radiator hose. When it gets real hot I've only got about a 5-10° difference between the upper and lower radiator hose. Any ideas? It's too damn hot to not be able to run my ac.
Once the temp gets up it doesn't cool down even doin 55 on the highway. It won't cool back down till I shut the ac off.
