Then either the Fan clutch is failing or the water pump is
When engine is cold, has sat overnight, open the hood and try to spin the fan blades
Should be hard to spin, fan clutch is cold locked
Start engine, you should HEAR the fan pulling air then after 5-10seconds it should get quiet, clutch unlocked
Shut off engine
Spin fan again, should be easy to spin
After driving and engine fully warned up, shut off engine, like when you get home
Open the hood and spin the fan blades, should be hard to spin, clutch heat locked to cool radiator
