Extended my axle dump exhaust out the bumper
Mackhedq
146
minnesota
If youre gonna be dumb you gotta be tough
Got tired of the drone on my axle dump exhaust. Even after adding a resonator it just was annoying around cruising speeds. Tube use is 2.25". Wish I had more 2.5" but this was free so I can't cry too much
franklin2
1,758
Virginia
Having the outlet of the exhaust exit between the road and the body can be very annoying. Just bringing it out to the side should make a big difference for you.
Rimjam
114
Huntsville,AL
2.9
Health is wealth
Looks like a tight squeeze where pipe goes over the frame. Don't let it touch the underside of the body, could start a fire in the carpet. Also.....that outlet on the left wall of your work area looks suspicious.
superj
2,578
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
that is the craziest exhaust run i have ever seen. y'all ran that pipe through every tiny spot it would reach. i would go out the side too. under the vehicle drove me crazy too
