fifth wheel question
4x4mike2004
6
Hazleton PA
4.squirill
i picked up a 5th wheel trailer and hitch from my buddy for a good price, however there are no frame to bed brackets with it. the 5the wheel mounting plate is wider than my frame. i have support brackets and cross pieces cut up to fit in between the frame and bed. would it be better to just weld it all together and weld it to the frame, or use a bunch of grade 8 bolts?
The truck is a dodge ram 2500 short bed, and the trailer is a 15 footer. I'm also a pretty good welder too.
martin
26
St Bruno, Quebec
1991
I would bolt it, I don't like stuff welded to frames but that's just my opinion.
17,848
SW Iowa
orfordguy@yahoo.com
Sweet Home Or
1978
197
For
The bigger the better
i know something about almost everything but not everything about anything.
hitch
my supercab has a 15K DTI hitch in it.. no brackets to start with made my own out of 1/2 plate and grade 8 bolts to both the hitch and frame... pulled a 40' 3 slide fifth wheel from K falls back to eugene for a freind before the engine gave up 2 months later...grade 8s and lock tight...:icon_thumby:
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
Use bolts... believe me.
The kits have two bolts per bracket...which makes 8 total to the frame.
The answer is unequivocally no, you cannot use your new 5th wheel hitch on your Excursion.
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
Its a joke.
True story, guy goes and buys a new suburban, goes down to the trailer and towing equipment store to get a hitch put on, comes back to the dealer irate because they told him he could tow with it and the trailer shop is telling him that they can't put a 5th wheel on it.
lil_Blue_Ford
6,131
Butler, PA, USSA
4.9L
Its a joke.
I wish I knew where it could be found at, I'm sure pictures are still floating around on the net... guy took a chevy blazer (the lil one), rigged up a sort of tailgate on the back and mounted the 5th wheel hitch to that, then hooked up a 5th wheel camper trailer...
Ozwynn
200
Berrien Springs, MI
RE Interceptor
there is a converter dolly available to tow a 5er with a Suburban/ Excursion. Jspafford has even posted a pic of one before.
mattpresley
13
Mesa, AZ
FORD F-250
6.2
Solid Axle Swap 4x4
No I am extremely curious bdab. Please go on.
Ozwynn
200
Berrien Springs, MI
RE Interceptor
heptofite
62
2.3 EcoBoost
that dolly would be horrifyingly unstable.
