Finally found my sport...
venom97
53
central,il
03-4/5 91-8.5''
This really looks good!! :)
Thank you! It turned out pretty close to how I had hoped. Next is some recovery points and Id like to eventually have a winch on it.
PNW Paul
72
Grit City
FX4
3" New Torsion Keys, Added Rear Leaf Springs (Suspension Only)
285 75R 16
Good looking rig - - have owned a first Generation Sport since 1993 (with a 3 year hiatus after commuting fuc-tard totaled it [found another]), but consider the James Duff "non-winch" bumper - - there's enough room to mount a winch between the frame rails. . .
Running a Ramsey REP 8000 winch . . .
Control box mounted behind grill
Control Box just to left of Warn fog light.
Paul
17,868
SW Iowa
Any pics of how the winch mounts?
PNW Paul
72
Grit City
FX4
285 75R 16
Just checked - - no pics of the mounting system, but pretty straightforward:
1. Two "L" pieces of steel that fit between the two frame rails/horns with the bumper nuts welded on.
2. Flat steel plate across the bottom and bolted to the "L" .
3. Winch bolted to the steel plate.
Biggest issue is clearing the winch clutch. . .
Ramsey Rep 8000 fits well between, and the clutch knob is small - - slides against the housing instead of larger "T" type handle, like Warn and many others.
Newer pic of a REP 8000:
(Note clutch is low to the housing of the winch, not perched on top like most other styles).
Could probably crawl around under the rig and take a few pics if the above description not sufficient, but not much to see without removing the front bumper (and I don't plan on doing that. . .). Let me know though, and I'll try an get what you need.
Paul
venom97
53
central,il
03-4/5 91-8.5''
Paul
Thanks for the info, I actually really like that. Sad to hear about the first exp....... Looks like this one is pretty slick, so everything worked out. hahaha
venom97
53
central,il
03-4/5 91-8.5''
And a recent picture since I havent posted in a while. We were able to get out this last weekend for a little ride. Always amazed by this little thing.
