Finally found my sport...
venom97
53
central,il
03-4/5 91-8.5''
This really looks good!! :)
Thank you! It turned out pretty close to how I had hoped. Next is some recovery points and Id like to eventually have a winch on it.
PNW Paul
72
Grit City
FX4
3" New Torsion Keys, Added Rear Leaf Springs (Suspension Only)
285 75R 16
Good looking rig - - have owned a first Generation Sport since 1993 (with a 3 year hiatus after commuting fuc-tard totaled it [found another]), but consider the James Duff "non-winch" bumper - - there's enough room to mount a winch between the frame rails. . .
Running a Ramsey REP 8000 winch . . .
Control box mounted behind grill
Control Box just to left of Warn fog light.
Paul
85_Ranger4x4
17,963
SW Iowa
Any pics of how the winch mounts?
PNW Paul
72
Grit City
FX4
285 75R 16
Just checked - - no pics of the mounting system, but pretty straightforward:
1. Two "L" pieces of steel that fit between the two frame rails/horns with the bumper nuts welded on.
2. Flat steel plate across the bottom and bolted to the "L" .
3. Winch bolted to the steel plate.
Biggest issue is clearing the winch clutch. . .
Ramsey Rep 8000 fits well between, and the clutch knob is small - - slides against the housing instead of larger "T" type handle, like Warn and many others.
Newer pic of a REP 8000:
(Note clutch is low to the housing of the winch, not perched on top like most other styles).
Could probably crawl around under the rig and take a few pics if the above description not sufficient, but not much to see without removing the front bumper (and I don't plan on doing that. . .). Let me know though, and I'll try an get what you need.
Paul
venom97
53
central,il
03-4/5 91-8.5''
Paul
Thanks for the info, I actually really like that. Sad to hear about the first exp....... Looks like this one is pretty slick, so everything worked out. hahaha
venom97
53
central,il
03-4/5 91-8.5''
And a recent picture since I havent posted in a while. We were able to get out this last weekend for a little ride. Always amazed by this little thing.
