Fuel line HELP!!!
bozone802
Montana
so i did dana 44/ford 9 inch swap to my 1999 ranger, and when i was grinding stuff off in the beginning i accidently chopped my fuel line. it is a steel line and i cannot find a splice kit or even a replacement anywhere, so if anyone has any info that might give me a hand please let me know. ford told me the part is now obsolete to them and no longer in their computers. please help me piece this thing together!
snoman6115
Weston, WI
v6 4.0
put a piece of fuel line with a id of the od of the split fuel line to couple it and put a hose clamp on each side
alwaysFlOoReD
5,173
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I'd do that^^^ using clamps with no holes, two clamps on each side of the splice, and high pressure line.
Richard
gwaii
2010 OTOTY Winner
2010 Truck of The Year
66
haida gwaii
460
a compression coupler will hold better,although if you make sure to use high pressure fuel line and clamps,the above fix should work-but you should bell the ends of the steel line first.
wahlstrom1
J-man HD Mech
2011 Truck of The Year
Forum Staff - Retired
21
Edmonton Alberta
Or if you can remove the line and have it silver soldered. I sucked a 1/2"drill bit through the nylon line in my frame rail and was able to use a splice kit, 5/16".
bozone802
Montana
thanks for the tips everyone, im gonna try to clamp it and if that doesnt work then ill put in a compression fitting. always start with the easy fix!
thanks again!
