- Feb 1, 2022
- 52
- midwest
- ford ranger
- Engine Type
- V8
- Engine Size
- 302
- 2WD / 4WD
- 4WD
- Total Lift
- 2" BODY LIFT
- Tire Size
- 33"
Define bulkheading if you would pleaseYou can fit it in the small hole. It's a pain in the ass but definitely doable. Use the right hose and solder a tab to hang it.
That is not the hard part
Bulkheading a small wire pass-thru with the little area available is the shitty part. Really isolating power is all you need to worry about. Grounds can use a tiny machine screw/nut. I have done the oring and sheet plastic diy bulkhead as well.
