Fuel tank clean?
juggaloscorpio
Sherman, Tx
2.3L 4cyl
We hardly get any kind of "freezing precipitation" here in north Texas but when we do, our whole freaking city is on lock-down. I destroyed my last Ranger in that frozen crap back in '09/'10 when we had a bad ice storm and I spun-out on an overpass which took my 2004 Edge and turned it into a paperweight/scrap pile. They only salt/sand the major roads(only 1 snow plow for the entire county lol), mostly for commercial traffic on the highways and emergency vehicles, but I am sure it is nothing like the northern areas. When I replaced my '95 EX fuel sender(3 times, thanks Airtex, a p.o.s. company), it was a P.I.T.A. to get that damn ring off but I will definitely take my time, I am fairly gentle on plastics. A couple of love taps with a rubber mallet and a plastic chisel(interior upholstery removal tool) will knock it free and the same to snug it in place when it is finished. Will post progress pics in a few hours.
juggaloscorpio
Sherman, Tx
2.3L 4cyl
Pretty much done with this project... only need a new filler hose and to reconnect all the lines and I can call it wraps. Here are some final pics from my lunch break job. Oh and the only "sediment" was from the old pumps floater paint but I am still going to replace the fuel filter as well.
juggaloscorpio
Sherman, Tx
2.3L 4cyl
Should I replace the entire filler neck/hose assembly or can I just get away with the outer rubber hose? Because wow that bad boy is almost 200$ for the entire assembly!!!! The filler hose itself is only $41+tax/shipping... Not trying to be a cheap a$$ on this part but damn, that just sounds like a lot for that 1 piece. Btw what body style do I have? Is the standard cab considered a "Styleside"? There are no flares, it is a straight body with nothing special about it.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
I looked at mine on the 82 that was in better shape than the 96 but when I tried to separate the outer from the inner I found that because they are formed hoses it would be next to impossible to pull out the inner and replace the outer...so I gave up on that idea and decided I would need to replace it.
Fortunately, I sold the truck before I had to go through that because those hoses are over $100 in Canada...so paying $42 or so would be a big savings...I was considering driving over the border and doing that job on a weekend...with the money I saved I could buy something else to go with it...like a new box or something...lol
juggaloscorpio
Sherman, Tx
2.3L 4cyl
Well dang... I will give it a shot at separating them and see how it goes... worse case I have to buy the whole assembly hahaha thanks for the heads up
juggaloscorpio
Sherman, Tx
2.3L 4cyl
Well that was easy... the inner tube is hardened rubber but still flexes and was super easy to remove... I had to cut it off the base of the filler opening first though.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
I think getting it out is the easy part...lol.
I remember now that one of the reasons I backed off on mine was when I cut away the outer hose I found the nozzle at the top had rusted through. Probably less likely to happen in your area but...Canada...eh!
If I recall also the outer hose needs to be fuel resistant (for good reasons) and if you can find one that you can fit over the inner and secure it...I think you'd be good to go...only concern for me would be vapour leaks...and their tendency to blow up while refueling...as long as it's sealed on both ends that is the main thing.
If you can figure that out you may have many people looking to you for a less expensive solution to the replacement hoses...that I tend to think are over priced due to the nature of their purpose...
juggaloscorpio
Sherman, Tx
2.3L 4cyl
Rock auto sells just the outer hose($41+tax/shipping)... I would think theirs are fuel resistant/not cause vapor leaks since they are marketed for that use and they are pre-formed for the filler line. I will order one and try it out though. In the meantime I am working on an interior overhaul as well, starting with the headliner then trying to tackle the seat issue(seems like the seats will be the biggest nightmare of any project in this truck).
juggaloscorpio
Sherman, Tx
2.3L 4cyl
Still can't find the body type... would mine be considered as a Styleside?
tomw
46
lima bean
vertical and above ground
Yes, styleside is the flat or slab sided, while flareside is the one with the fender bumps over the wheels. Also called a stepside, but that may be 'brand' naming stuff.
Depending on how long Rock would take, using piece or sheet of fuel resistant rubber and some fuel resistant RTV or rubber cement, you could wrap the cracked area with a sheet, overlap, glue with cement or RTV, use some tie wraps, and have a serviceable fuel filler that was sealed. Dunno how long it would last. Wonder if inner tubes are fuel resistant, as that might be a good candidate. The thing to worry about is fumes. The liquid fuel would be below the level of the tank inlet for 99% of the time.
Have you noticed any dripping or path of liquid fuel trailing down the side of the tank with your current filler tube? If there's no liquid, just forming a gas-tight seal may be effective. Some fillers are NLA, so Rube Goldberg starts to go to work.
tom
juggaloscorpio
Sherman, Tx
2.3L 4cyl
tom
Yeah that is definitely not happening now since I sliced off the outer tube lol
tom
No leaks from what I saw before I cleaned up the tank. I don't believe there was ever any issues with the filler tube other than it being cracked(the only real reason I am replacing it while the bed is off) and I don't think the last owner even knew it was cracked tbh.
I am buying the new outer hose today so we will find out if it is an easy fix or a wasted $41+tax/shipping.
