gas peddle vibration
86ranger4x4owner
2.9l
I have a vibration when i accelerrate and from a stop in my gas peddle. I have a 88 supercsb ranger. Would could cause this? I have done the zip tie trick but could that cause my problem?
killj0y
11
Edinburg, TX
2.3l 4 Banger
Fix it till its broke!
does it vibrate at the same frequency as the engine? nothing else is vibrating? I would think that the throttle cable is tight against something (like some part of the engine) transferring the engines vibration maybe? as far as i know the peddle is just bolted up and the cable is really the only thing attached in a significant way.
86ranger4x4owner
2.9l
It feels like it vibrates only when i rev the engine or give it more gas to accerlate but doesnt vibrate at idle.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
I had a vibration on mine...but it was the breather was not tightened down...twisted the butterfly nuts down and the vibration went away...so look for something loose...like a heat shield...or anything...doesn't have to be touching the throttle cable, just something that is loose...you will probably hear or see something if you pop the hood and rev the engine...
86ranger4x4owner
2.9l
I got under there and had someone rev it up and couldn't see anything loose or hear anything. Any other ideas?.
