Thanks! I like the square links too.
Anyway, I've hit a snag. I can't decide how to make a transmission mount. The drive shaft is in the way of going across the frame rails. And I can't mount it under the frame because there is a possibility the radius arm could contact it.
So, what I've come up with is build a removable mount from the radius arm mount. It will be built out of 2x2 .25" square tubing. It will come out at an angle from the link and will basically look like a flat hill top. I'm thinking about adding a brace to the passenger side frame rail but that could interfere the exhaust. It is going to be removable. Is that going to be strong enough? Its approx 8" away from the radius arm crossmember.
I will have another crossmember holding up my np205 at the back of the tcase.
