swynx
- Mar 26, 2008
- 9
- Age
- 31
- lewiston idaho
- Mazda
- Engine Size
- 4.0
I paid a total of 204$ with s&h. Being from harborfreight I exprcted junk. That's not the case. I expected sloppy ratchets that took alot of motion to click over. Go to home depot and play with some husky ratchets that's what you'll get. Very small movements for the click. Its got just about all the sockets you will ever need. .. all the way up to inch and a quarter. Tons of torx tools. Sockets range from 4mm-32mm. Compared the sloppyness of the sockets to my autozone greatneck set and these are nearly perfect fit while the greatneck set is sloppy. The case has metal clasps on it and a spot for a lock.
My complaints? 50 lbs is alot for a plastic case. I've only carried it by the handle once and it bowed out the further I carried it. I carry it with both hands now.
And the supply of wrenches is next to none. But most people have a decent supply of wrenches and there not to expensive.
I honestly have only the above 2 listed problems with the product. I would recommend it as a first tool kit or to re -up your supply. Ill upload photos once photobucket is fixed
