Heater Core or Blend door acuator?
deeman
2008 Ranger XLT
So a guy needs help diagnosing an issue on a 2008 RWD 3.0l
3 weeks ago when I started it and turned on the AC I had a blast of steam come thru the vents. I stopped and there was a really big amount of vapor coming from under the hood right near the heat exchanger.
I did smell coolant and continue to smell coolant when turning on the heater however the windshield fogs up bad (coolant vapor film?) and my defrost seems to blow heat but the windshield never unfogs
So…..heater core is bad, right?
But the heat works perfectly and my engine temp is not abnormal at all.
I have no moisture or dampness on the passenger footwell
I thought a heatercore issue would not produce heat and my engine temps would be abnormal.
Could it be the blend acuator?
Any way to rule in or out a bad heatercore?
Thanks
rusty ol ranger
2.9 Mafia-Don
7,502
Michigan
177 CID
Could it be the diverter?
Thanks
Nah...a plugged core wont make heat...but a leaky one will...and make everything foggy and stink like coolant.
Strange your floors not wet. But im still betting the core is shot
rubydist
858
Denver
Ford Ranger FX4
Typical symptom of a heater core with a smallish leak.
The blend door actuator has no ability to make those kinds of issues.
deeman
2008 Ranger XLT
Okay, thanks guys - I also suspect the HC needs to be replaced but I wanted to check to be sure.
rubydist
858
Denver
Ford Ranger FX4
If the heater core has a small leak towards the top, the heat from the circulating hot coolant can evaporate all of the leaking coolant before it can make a wet floor. That is likely why the windshield is so fogged up. Alternatively, it could be running into the engine bay on one of the inlet/outlet ports so it never drips inside the cab.
