MadMax_636
- Nov 7, 2019
- Reaction score
- 47
- Age
- 28
- Location
- Georgia
- Make / Model
- Ford Ranger
- Engine Type
- 2.8 V6
- Engine Size
- 2.8L
- Manual
- 2WD / 4WD
- 2WD
- Total Lift
- However much it goes up when I get my fat ass out.
- Total Drop
- How much it goes down when my fat ass gets in.
- Tire Size
- Dry rot and old
Today I was thinking about rewiring my ignition system just to clean stuff up. So I checked my battery voltage (12.98v) and then I turned my ignition ON and checked the red/hot wire going to the HEI module, it was only reading 10v I even unplugged it and tested the same wire directly to the battery ground and got the same results.
I then started the engine and let it sit on high idle to warm up.
Battery voltage now is at 14.2-14.4v
The red/hot wire stayed the same.
I'm wanting to rewire my ignition HOT and ground right off the battery. I want to use a switched relay to just trigger it.
Could I get some information on the results of my current findings and help on rewiring it? I'm hoping to get a hotter/cleaner and more consistent spark.
