HEI converted ignition - Ignition module hot wire from harness only has 10 volts according to multi meter
MadMax_636
47
Georgia
2.8 V6
2.8L
However much it goes up when I get my fat ass out.
How much it goes down when my fat ass gets in.
Dry rot and old
Today I was thinking about rewiring my ignition system just to clean stuff up. So I checked my battery voltage (12.98v) and then I turned my ignition ON and checked the red/hot wire going to the HEI module, it was only reading 10v I even unplugged it and tested the same wire directly to the battery ground and got the same results.
I then started the engine and let it sit on high idle to warm up.
Battery voltage now is at 14.2-14.4v
The red/hot wire stayed the same.
I'm wanting to rewire my ignition HOT and ground right off the battery. I want to use a switched relay to just trigger it.
Could I get some information on the results of my current findings and help on rewiring it? I'm hoping to get a hotter/cleaner and more consistent spark.
8,370
Well it wouldn't start if you didn't have at least 8v on the "hot" wire
Red is just a color, not always what a wires purpose is
Do you have a 4 pin HEI?
If so the connections are like this: https://forum.ih8mud.com/attachments/duhp-jpg.1273436/
The B tab is the hot wire and its also connected to the Coil's + terminal
Key on should show Battery voltage, as tested also with key on, on the B wire and at the Coil's + terminal
Wired diagram here: https://www.allpar.com/attachments/hei-mod-conv-jpg.4496/
MadMax_636
47
Georgia
2.8 V6
2.8L
Dry rot and old
Yup, thats what I have. I tested it and running "B" is only getting 10v
MadMax_636
47
Georgia
2.8 V6
2.8L
Dry rot and old
I shut the engine off. Turned the ignition to ON and the "B" and "C
franklin2
1,758
Virginia
10v sounds like the resistor wire. You should be using the original hot wire to the original square coil. I think it was a red/lightgreen wire.
2011Supercab
467
Washington
Toyota Tacoma
MadMax_636
47
Georgia
2.8 V6
2.8L
Dry rot and old
UPDATE: So here is what I did.
I ran a direct wire from the battery + to the battery + on the HEI. It instantly ran better, smoother, and picked up in RPM and idle vacuum.
I tried to shut the car off with the key. It didnt work. So I unplugged the ignition HOT wire on the HEI and it shut off. So IDK why its reverse powering the system.
I did test the voltage with the direct power lead and it was reading 13.95 vs the 14.10 from the battery directly.
MadMax_636
47
Georgia
2.8 V6
2.8L
Dry rot and old
Heres a video of the wiring. So for those who might be able to ID the colours of the wiring.
I will do a better video in the morning with morons are firing fireworks off in the middle of the night in the woods...
Plus, Ill get a better look/view of the colours or the wiring... Since I clearly didnt in this video
8,370
The earlier Ford Rangers had a Ballast resistor on the firewall, can't miss it, big white ceramic rectangle
Looks like this: https://m.media-amazon.com/images/I/51-j+mhBCEL.jpg
It needs to be removed from the circuit, unplug it and connect the 2 wires together
Ignition switch(ON)--------------ballast resistor------------------coil "+"/HEI "B"
Ballast resistor SHOULD lower the voltage by 4 or 5 volts, but its not needed with newer spark modules and coils
What you want
Ignition switch(ON)------------------------------------------------coil "+"/HEI "B"
MadMax_636
47
Georgia
2.8 V6
2.8L
Dry rot and old
MadMax_636
47
Georgia
2.8 V6
2.8L
Dry rot and old
What you want
Tomorrow Ill look at it and see what I can do in terms of cleaning/fixing the wiring up.
8,370
On the 2.8l, and most other Rangers in the 1980's, Ford use a Red/light Green stripe wire from the ignition switch thru the firewall to the engine bay and then to the Coil "+" and spark module
No fuses just the red/green key on 12volt wire
MadMax_636
47
Georgia
2.8 V6
2.8L
Dry rot and old
what about this? From when I first did this @RobbieD sent/posted this diagram for me. It says Brown/Pink wire is ignition 12v
RobbieD
2.9l Mafia
3,464
Georgia
Small world. I was typing the following as you posted.
According to EVTM, on the '84's there's two wires at the ignition switch which go to the coil, Red/Green (ignition) and Brown/Pink (start). These two wires are connected together before getting to the coil, so that there's voltage in both key positions..
There's two ignition systems, one of which has a resisted ignition wire and a full voltage starter wire. Off the top of my head, I think the MCU system (resisted ignition) is for 4 cylinders, and the 2.8 should be the EEC system.
The EVTM pages are below.
I'm not sure what's going on with yours. Try measuring Red/Green at the ignition switch; if it's 12V there and much less at at the coil it sounds like it's a resisted wire. In that case you could add a wire length at the switch and to the coil to bypass the resistor.
At the (old) coil, did yours have a Red/Green wire or a White/Blue hash wire?
MadMax_636
47
Georgia
2.8 V6
2.8L
Dry rot and old
I honestly dont remember what the original wire colours were. I tired looking on the dead horse of a thread (The one that started my conversion and that included every horrible step I too haha) but I couldn't find photos of the wires. I found that diagram you had sent me but that was all I really remember of that. Since I haven't touched the system since it runs great besides the 10v spark system.
