HEI converted ignition - Ignition module hot wire from harness only has 10 volts according to multi meter
MadMax_636
47
Georgia
2.8 V6
2.8L
However much it goes up when I get my fat ass out.
How much it goes down when my fat ass gets in.
Dry rot and old
OK. I'm hoping that @RonD comes back and weighs in the voltage drop when running.
I looked everywhere for a Ballast Resistor under the hood and under the dash. Nothing.
A idea that I had was splitting the 2 wires and running the 12v run (red/light green wire) and running it directly to the HEI "B" post. Since its only powered with key on RUN and the (Brown/Pink wire. Mine just looks brown) and keep it on the harness. Or even running a T from the harness connector and the HEI "B" directly?
RobbieD
2.9l Mafia
3,557
Georgia
I would lean toward just adding a simple relay to switch good battery voltage to your ignition, the relay being triggered by the original wire.
8,372
just did that. in the RUN position im getting around 12.65v and when running I'm getting 10v
And what was battery voltage at that time of the 10v test engine running, past battery voltage test doesn't matter for something like this, have to retest everything at that one time.
And test running voltage from "red wire" to alternators metal case and then to battery negative
Also test HEI ground to battery positive engine running
A corroded connection will cause this kind of voltage drop
A volt meter is not "a load", maybe 0.02amps, a running coil and HEI is "a load", 5 or 6amps
So static test of key on voltage can show correct battery voltage, but "load" test can show significant voltage drop if higher AMP draw is restricted by a poor connection
8,372
There is no Ballast Resistor if you see Battery Voltage at the coil and HEI in key on static test
You can redo the Splice of red/green and brown/pink wires to one new wire in the cab
And run that new wire to coil and HEI
But you must have BOTH of these wires hooked up to the one wire for coil and HEI
MadMax_636
47
Georgia
2.8 V6
2.8L
Dry rot and old
I will say I didn't test all of that but all throughout the tests. Ive tested the battery voltage before and after starting and running. They all read 12.75 (Not running) and 14.25 (when running).
I'll run a direct ground from the battery, engine, and the HEI once I've got wires and the connectors. Since I'm currently all out. The only place near me that sells wire is Harbour Freight, and they want way too much since it comes with some sort of storage thing.
MadMax_636
47
Georgia
2.8 V6
2.8L
Dry rot and old
So your saying I could run a wire T? Keeping the wire on the connector but running a new lead directly to the coil/HEI?
franklin2
1,769
Virginia
I would keep investigating this.
Instead of guessing it's a ground problem, set your meter up like you have been doing and get the 10v reading at the HEI. While it's running with the 10v reading, keep the + of the meter on the HEI. but move the negative meter lead over directly to the negative battery post. If the meter reading is higher with the negative of the meter on the negative of the battery, then you do have a ground problem. If it's the same, it's not a ground problem.
If it's not a ground problem, go into the fuse panel and poke around in there with the truck running. If you get 10v in there also, then you have a main power feed problem somewhere. When you find it, the whole truck is going work better.
MadMax_636
47
Georgia
2.8 V6
2.8L
Dry rot and old
UPDATE: I did a few ground test. I dont think its a ground issue. So I went under the dash and poked around with the multimeter and honestly didnt find anything out of place. Will do more testing later. I did run a jumper wire from a 12v HOT on run to the HEI "B" and it ran and stopped perfectly... until it overheated and shut off... I unhooked the wire and it fired right back up zero issues... I touched both the HEI and it was hot but the small heat sink was ultra HOT. Like to the point, a drop of sweat turned to steam as it dropped off my face... So then I said... NOPE! I left it at the 10v until I can get a more active heat sink with a fan before I go w/ 14+ volts...
Im gonna try and repurpose a old intel or AMD desktop heatsink and fan and wire the fan and "B" to the same hot lead.
franklin2
1,769
Virginia
If your fuse box is good, then you must have a problem just on that wire feeding the HEI. I will have to test mine and see what voltage I get on the HEI module. It's been running fine but I am curious now.
MadMax_636
47
Georgia
2.8 V6
2.8L
Dry rot and old
Let me know what your findings are.
