2.5L ('98-'01) Help with 2.5
jjpp250
Central, CA
2.8 V6
5.5” + 2.5”
32/11.5/15 33/12.5/15
this is my first time working on a 2.5l 8plug ranger. I was changing the powe steering pump, plugs and wires and 1 coil pack. Well I have work on engines for years so it not that I am new at all. First off every time I let off the throttle the truck wants to die. I checked for vac leaks crossed wires every thing I I could 2 times. Second I have a worse whining sound in the pump than before. I have jacked up the front and bleed the pump for for some 10 min or so. I am going to try to bleed it a little more with someone to watch for air bubbles.
franklin2
1,758
Virginia
Ford power steering pumps are famous for the whining noise. Some do it worse than others. I think Ford had a special procedure to put a vacuum on the reservoir to try to get the air out of the fluid, but that didn't work sometimes. And then you get a worn out rebuilt pump from one of the rebuilders, and the whining can be worse. You may have to live with it.
racsan
4,443
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
You can try putting in some of that thick lucas stuff.
or turn the radio up
-Nate
56
Sunny So. Cal. Land Of The Weird
Ford Ranger XL
2.5 (4 Cylinder)
Nothing is so difficult it cannot be overcome by brute force and ignorance =8-)
Thanx for the heads up on the P.S. whining, my 2001 with 140,000 miles *just* began doing this and I've been changing the P.S. fluid at every 3,000 mile HOT LOF until it remained red and sweet smelling .
Too bad they don't have a filter in there like my old Mercedes Diesel taxi ~ I'm almost to 1/2 million miles and so far only P.S. fluid, filters and seals, it still works like new .
Too any fail to ever change the P.S. fluid the *instant* it gets dark or begins to smell burned .
