Help with brake line flaring
hr8882
New Jersey
After years of flaring steel brake lines sucessfully I decided to use Ni copper line because
of constant corrosion here in the NE. I can't get this new line to double flare without the flare
breaking or cracking. what am I doing wrong ? Is there a certain technique thats different
than steel line.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
i aneal it first with propane, go a little bigger then normal on the bubble and watch carefully on the foldover...as soon as it seats after breaking over i stop and let the rest of the seat form on the make up in place.
cvar
19
Mazda
4.0L V6
I had no trouble flaring the NiCu lines. Perhaps your flaring tool is bad? I used a brand new one from Autozone, and it worked every time. I was careful to cut the tubing off squarely, filed it smooth, and gently reamed every piece before flaring. I used a drop of oil every time I applied the flaring tool. No cracking. See photos here: ( http://imgur.com/a/sUnMy ) <== CLICK
Oh, and I didn't crush the double flare with excessive force. Maybe you're too strong for this?
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Excellent write up CVAR!
I did my entire brake line and hoses about 8 years ago and only had to go back and redo the rear driver side due to a brake cylinder failure. It is starting to rust a bit at contact places but otherwise in good shape. I did the zip tie thing with mine since I had the same problem of finding replacement clips.
And...I also bought pre flared lines for the MC because I still have no idea how to make the flare properly for that application. For the rear brakes I bought a 3 or 4' length and put a line joiner to finish the rest because I didn't want to drop the tank. Only problem I had was measuring the line to the rear flex line, but there is a bit of room to play with that so I was able to flare the line standing up instead of lying down.
I had to cover the end of the line to feed it past the gas tank because I didn't want to risk getting any crud in the line...just taped a rag around it and fed it past the tank...even though my frame rails were recently cleaned and painted.
And I hung the lines as high up on the frame as I could to keep them away from possible buildup along the rail...even though I haven't seen that too much on most trucks.
hr8882
New Jersey
Thanks for the reply, I'll give that a shot. That is one advantage to NICU is the ability to form to the flare seat.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
yeah, i like it. i want to do my whole truck with it, hopefully sooner then later.
i had no issues a few years back on the first few coils i got to use, and then i had some splitting and hard forming with a few coils...so i tried the propane and it went much better.
not smashing the seat like i do with reg line has resulted in no issues.
i just assume theres a bit of variance in manufacturing, and likely most of the time hitting it with the propane now is a waste of time. of course redoing a flare is a waste of time too so its just been a routine.. but its a great product to work with in the salt belt.
