- Apr 22, 2014
- 157
- Ohio
- Ford
- Engine Type
- 2.9 V6
- Engine Size
- 2.9
- 2WD / 4WD
- 4WD
- Total Lift
- 3in
- My credo
- Clean your room before you criticise the world.
88 single cab 2wd to 4wd swap 2.3t setup to 8lbs of boost just enough to turn 31s I have a matching set of 1/2 tons from a 70s Ford plan is turbo set up first toss in a set of forged pistons and smack a turbo on it and run stinger performance's ECM (megasquirt variation) it says it's plug and play with a map sensor run it 2wd until I get the time to get a good 2.3 4wd 5spd trans and electric t case I'll use the shiftster thing for it so I'm not hacking a hole in the floor then run it 2wd still just with a shorter d shaft to the rear on stock axel then swap the rear to my full width 9in then when time permits again I'll swap my d44 in and be done!!!! Also a fancy James Duff winch bumper and my Smitty built winch I caught on sale awhile back so let me know what you guys think and sorry for the spelling errors this phone is not a good one
