Here's the plan
Mightyfordranger
157
Ohio
3in
Clean your room before you criticise the world.
88 single cab 2wd to 4wd swap 2.3t setup to 8lbs of boost just enough to turn 31s I have a matching set of 1/2 tons from a 70s Ford plan is turbo set up first toss in a set of forged pistons and smack a turbo on it and run stinger performance's ECM (megasquirt variation) it says it's plug and play with a map sensor run it 2wd until I get the time to get a good 2.3 4wd 5spd trans and electric t case I'll use the shiftster thing for it so I'm not hacking a hole in the floor then run it 2wd still just with a shorter d shaft to the rear on stock axel then swap the rear to my full width 9in then when time permits again I'll swap my d44 in and be done!!!! Also a fancy James Duff winch bumper and my Smitty built winch I caught on sale awhile back so let me know what you guys think and sorry for the spelling errors this phone is not a good one
redhurricane
Westminster, Colorado
2.3
A) Punctuation is your friend.
B) what trans do you plan on using for 4x4, and what transfer case?
The 8.8 from 95+ explorers is nice, LSD, typically 3.73 gears in most. you may find that ratio a little tall for 31" tires. you'll spend less time doing fab work than you would with the 70s F150 drum brake axles and get disc brakes out of it.
You also may find that you can acquire a complete turbo long block with turbo for less than you would trying to piece meal this together. there's a TF facebook page that usually has lots of things being sold-
https://www.facebook.com/groups/TurboFord/
Mightyfordranger
157
Ohio
3in
Yeah sorry about the poor grammar lol but I plan on an fm146 I'd like to use a m5od but I don't think they were 4x4 at any point. I do have one on hand but it's an external slave style. I do know that they aren't much for withstanding HP but im thinking 8lbs of boost should be ok
turbo91xlt
63
Goshen, NY
1992
I'd only use the m5od behind a 2.3t. They came in every '88-'97 2.3 4wd truck made. If you have to you can make a 2.3 4x4 m5od out of a 2wd 2.3 m5od & a v6 4wd m5od but it requires full disassembly of both trans to get the necessary parts. I hoard 2.3 4wd m5od trans because they are fairly hard to come by. Also suggest going with a 1354m t-case if you can find one.
don4331
1,352
Calgary, AB
5.3
As someone pointed out in one of the other threads, there are several hundred 2.3l M5ODs for 4x4 available on car-part (and you could get your transfer case and driveshafts at same time) just about anywhere nation wide.
Mightyfordranger
157
Ohio
3in
You all make good points but I haven't been able to find a thread on here that shows how to identify the difference between the two
scotts90ranger
4,416
Dayton Oregon
2.3 Turbo
what do you mean difference between the two?
You don't have to cut a hole in the floor for either a 1350 or 1354 manual T case, there's a bolt on plate, take that from the donor rig... all '88 up 4 cylinder 4x4 Rangers have a M5OD as previously mentioned and will handle the most power of any option. If you are asking the difference between the 1350 and 1354 T cases, all '90 up are 1354 and have a fixed front output where the 1350 has a slip spline on the front output other than the STX versions that had a different fixed front output than the 1354 does...
