Horn
bottomdollarjack
My 94 horn stopped working all of a sudden, checked fuse,horn,changed horn,wth,no cruise control, HELP
8,372
No horn relay if there are no cruise buttons on steering wheel
Clockspring wire could be bad, or the switch itself
No airbag on 1994 Ranger and with no cruise should be easy enough to remove the cover and test for 12volts at the switch
bottomdollarjack
Is switch the white thing the two wires go to
Angry Possum
No Fat Chicks, Truck Will Scrape
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
Sometimes you eat the bear, sometimes the bear eats you.
Worse comes to worse, you could try running 2 temporary test jumper wires (a negative and a positive wire) from the battery directly to the horn, be careful doing it. I trouble shoot that way often. It works out for me much better, going right to the source. I'm not sure horns really go bad, it never happened to me on any of my vehicles. My horns always seemed to work. I'm thinking your issue is definitely electrical,, perhaps a relay, a fuse, or loose wire connection etc Try the jumper wires first.
bottomdollarjack
But where is horn switch located
RobbieD
2.9l Mafia
3,558
Georgia
The horn switch is in the center pad piece. Remove two Phillips from the back of the steering wheel spokes and then rotate the pad upwards.
bottomdollarjack
Do you have a pic of it
bottomdollarjack
All I see is a metal plate,two wires plugged into something
SenorNoob
590
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Does it look like the one in this ebay ad?
EBay Ranger steering wheel
If so, the 2 wires on the back of the pad are for your horn switch. Should be able to test them with a multimeter or test light and battery. If everything else is working, touching those 2 wires together would cause the horn to blow.
I wouldn't be surprised to find that the pins going to the pancake ring (the circles on the back of the steering wheel) are gummed up and not making contact. I would try to find the wires farther down the column before taking the wheel off tho.
bottomdollarjack
Hi I have taken the whole front off steering wheel pad apart, have seen no switch
bottomdollarjack
Yessir it does
8,372
There should be 2 wires, the wires are plugged into "the switch"
One wire is 12volts IN, full time, not just with key on
Other wire is 12volts OUT to the horn
"The switch" can be two larger metal plates, with insulators between them and the upper plate will tilt/move to make contact with lower plate which connects the two wires and sounds the horn
bottomdollarjack
What if it doesn't
