How do I get this seal in
2.9._ranger
24
texas
ford ranger
I have m5r1 and the rear seal broke and I took the old one out and got a new one but I can’t get it to go in
The pictures are of where the old seal was and the side and back of the new one
If anyone could tell me how to get it in I would appreciate it very much
2011Supercab
467
Washington
Toyota Tacoma
The red part goes into the transmission, the black rubber part goes on the outside
2.9._ranger
24
texas
ford ranger
Yes I know that but when I try and push it in it won’t go in
2011Supercab
467
Washington
Toyota Tacoma
You can't just push it in, you have to carefully tap it in with a hammer.
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
I’ve tried that and it still doesn’t go in
If it's the right seal, it will go in. They are extremely tight. It must go in straight. Tap a little on one side then the opposite side. Keep working back and forth, tapping on the part that sticks out the most, trying to keep it even until the flange is against the transmission. If you have a piece If pipe the same diameter as the metal part of the seal, you can use that and hit it with a hammer. That sometimes helps them go in better.
There are special tools for driving seals.but you probably don't want to buy them.
2.9._ranger
24
texas
ford ranger
I believe it’s the right one AutoZone said it was and I even checked rockauto to make sure it went with the right transmission code, I’ll try and see if I can get it
SenorNoob
569
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
I see you have an 89 with 2.9. Sure the store didn't get you a seal for the FM146? Try to look at the part for numbers. It's silly how often I've gotten parts IN THE WRONG BOX.
2.9._ranger
24
texas
ford ranger
I see you have an 89 with 2.9. Sure the store didn't get you a seal for the FM146? Try to look at the part for numbers. It's silly how often I've gotten parts in the wrong box.
I’m pretty sure it looks just like the m5r1 coded one on rock auto
r-hindl71
Papa R
20
Omaha, Nebraska
Ford Ranger XLT
235/75R15
Assuming you have the correct seal I have used a length of pvc pipe with a cap on it to drive in seals before, you have to make sure that the diameter of the pipe contacts the metal rim of the seal and does not damage the rubber.
rubydist
858
Denver
Ford Ranger FX4
The parts stores like Advance Auto also have tool sets you can rent or buy to install seals and bearings.
19Walt93
4,467
Canaan,NH
351
3"
235/55R16
I use a big socket as a driver but a piece of pipe would work, too. Make sure the drain hole in the boot faces down. I prefer seals with boots like that because they help keep dirt away from the inner seal surface.
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I typically use a socket myself.
But I thought that the hole was a vent and placed it on top.
ericbphoto
16,598
Wellford, SC
6"
Sockets work great. But that seal is probably around a 2" diameter, at least. Noy many people have a 2" or larger socket. The PVC pipe idea is great and relatively inexpensive.
A seal driver set that I used at work recently was actually some kind of plastic and it was a high dollar SKF brand thing.
ericbphoto
16,598
Wellford, SC
6"
You can carefully drill a new drain hole in the bottom.
