I have made my decision, but need a little help with backspacing
paosgravity
24
KY
Ford Ranger XLT
Can you guys help me with backspacing and fitment for these wheels?
I've poked around the forum but still don't quite understand how to determine if these will work, so hopefully an expert can give me a definitive answer - I DO believe I have figured out that the bore will work, but backspacing is like another language to me. I'm planning on a 5/6 drop on my '04. Also any tire size help would be great.
THANKS GUYS!!!
tinman_72
136
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
Looking at the page you linked to, they state that they fit a 2004 Ford Ranger XLT Extended Cab Pickup RWD.
paosgravity
24
KY
Ford Ranger XLT
I'm worried about rubbing in the front with that backspacing - wasn't sure if I needed to have spacers ready when they get here, or wait and check.
MSGia
124
Central Florida
4, 5
The bolt dimension is right. I would wait until you get them and check, but it's looking like you'll need spacers. As for tire size, my 17s are 7.5 wide and I have 235 width. Just looking online it looks like people are using anywhere from 225 to 245 width and 30 to 45 sidewall. Can't wait to see the build.
paosgravity
24
KY
Ford Ranger XLT
Thanks for the input.....unrelated, what year grille do you have?
MSGia
124
Central Florida
4, 5
I wonder if that would fit my '04.
Send a picture of the front, I’m not sure what a 2004 front grille looks like, it could fit but not sure.
JoshT
1,734
Macon/Fort Valley, GA
It should. 2004 was the last facelift for the Rangers. Bumpers changed, but everything else pretty much stayed the same. 2004-2010 shared the same headlights, header panel, and hood. Header panel is the part that the grille and headlights mount to.
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
647
Central Indiana
Back to the wheels, a backspacing of 4.54" = offset of 1mm. So, the wheel mounting surface is essentially centered in the outer barrel of the wheel. This can be confirmed here, where they list the same wheel size as "18X8 01mm".
An offset of 0 would be perfectly centered. With 1mm positive offset, it would push the wheel out away from the frame 1mm.
On an 18X8" wheel, I wouldn't expect any rubbing issues unless you choose a tire with massive sidewall. I run an 18X9" wheel and 245/35 tires on my truck with 4" of drop in front and don't have any issues. My wheel offsets are different than what you're considering, and I'm not quite as low but you can go fairly wide up front as long as you're not going too positive or negative with the offset.
paosgravity
24
KY
Ford Ranger XLT
Can you tell a large difference in your speedo? I'd like something at least in the back that keeps my speedo where it should be.
I was looking at 245/50/18 (rear) and 225/50/18 (front), but that still seems like a lot of sidewall. I DO plan on still using this as a truck to a certain extent, and roads aren't the best around here, but still....
MSGia
124
Central Florida
4, 5
That’s how I found out before I upgraded wheels and tires.
JoshT
1,734
That's in your tire size, not wheel size. To keep speedo the same you need to keep outside diameter the same. That said it might be a little difficult to do with a 5/6 drop, or it might not be difficult at all. I have no idea what size a 2wd would come with stock or how much clearance you have to lower.
paosgravity
24
KY
Ford Ranger XLT
225/70/15 is stock - I've ran the numbers and measured on the truck - going to be close to run the stock wheels in the winter - may have to get smaller tires in the front too keep from rubbing.
paosgravity
24
KY
Ford Ranger XLT
Thanks man!!
No members online now.
