I have the Ford 8.8 28 spline LS, worth upgrading to 31 spline?
nooch450
4
New Jersey
4.0 OHV
I agree about the Auburn, I've seen those things in action several times myself.
In spite of marketing claims saying otherwise, the ECTED is NOT a locker at all (there are no locking pins, splined engagement gear or anything of the sort inside it). It's a limited slip diff that simply tightens up it's clutches when you "engage" it. Even when brand new they don't "lock up" well.
If you want a locker, the ARB or Yukon ZIP is what you're after.
I was looking into the OX locker for the rear, with the mechanical linkage...
I may want an auto locker in the front though...
dla
I have the stock Ford 8.8 28 Spline LS rear in my truck, I want to run 4.56 and an Auburn Electric Locker... It it worth putting into this axle or should i try to find a 31 Spline Axle?
Id rather reuse mine unless there is a good reason somebody wants to talk me out of building the guts of the 28 spline with a locker n gears...
Basically, is it worth finding a new axle (31 spline)? Or is mine strong enough...
It doesn't take much to have more invested in your rear axle than the whole truck is worth.
cdawall
U.S. Military - Active
5
Ellsworth AFB
4.0L V6
You would be a lot better off putting a selectable in the front and an auto locker in the back. Trust me. Unless you have hydro assist you are going to want to be able to flip a switch and flip the front off. The ass end wheeling could be welded and you will still drag it through corners without binding.
nooch450
4
New Jersey
4.0 OHV
I only want to use 4x4 if the truck is stuck... and ill use Manual locking hubs, so if i need 4x4 ill lock the hubs and than the auto locker will kick in if needed... but while running my truck hard with lots of travel id rather keep the front stuff from spinning at all unless i get stuck... I dont wana weld my rear or the rear tires will burn off on the road... and i dont want an auto locker because they can be wreckless and kick in when you dont want them to causing you to spin out and crash..
Hagan
08/2013 OTOTM Winner
11
Salem, OR
2.3
I wouldn't build a 28 spline it has same bearing and shafts as the 7.5"
The only difference is the axle shafts, axle tube diameter (maybe thickness?), and outer wheel bearings/seals from a 28 spline to 31 spline 8.8.
The ring and pinion and pinion/carrier bearings are the exact same on both 8.8's.
I bought two auto lockers for my Ranger (F-150 8.8/Dana 44) for $500 new. ARB's are nice but this is 1/4 of the price:icon_thumby:
I've never had a traction issue or spinning out caused by the locker. You can feel it when you go around corners slow and when you take off turning. You have to change your driving habits but I'm willing to sacrifice that.
Maybe put a selectable locker in the front (cheap) so if you get stuck the only time the locker will work is when you'll need it and when you lock the hubs. It won't cause you traction issues and you won't even know its there.
cdawall
5
Ellsworth AFB
4.0L V6
Auto lockers don't cause you to spin and die...it's your choice man just letting you know it is alot easier to control a selectable front than one with an autolocker. I do however play out in the rocks so if you are goofing in the mud or whatever I could maybe see the rear selectable. For rocks it is night and day with a front locker and an autolocker will kill power steering pumps without hydro assist.
Between a 31 and 28 spline 8.8 you have bigger bearings for the shafts (the load bearing ones), substantially thicker tubes, and substantially thicker shafts. It is effectively a narrow F150 axle and is load rated as such. The 28 spline is a 7.5" with a swapped pumpkin the only parts you cannot interchange is the ring gear and carrier.
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
I must be doing it wrong, I've easily driven 75k on auto lockers :dunno:
Hagan
11
Salem, OR
2.3
Exactly:icon_thumby:
Just get an auto locker. Its better to have a locker than be stuck and wish you had one!:icon_thumby:
Dugan
12
New Castle, DE
Ford, IH
2.9L, 355 SBC
Im in new jersey...
What part of jersey you must live near me... cause the yards in my area like to bend you over and give no courtsy reach-around or spit
kevinsranger
edison nj
FORD
you guys gotta keep an eye on craigslist, central jersey, i see expo 31 splines all the time on there, i dont buy one cuz i have one sitting in the garage collecting dust waiting for me to get off my a$$ and put it in
