interchangable parts list
MikeG
752
central Texas
B4000
2"
235/75r15
Yes, with the Explorers you can actually steer them, rather than herd them gently in the direction you'd like to go......
Night and day difference between my TIB truck, and the Exploder from one year earlier......
Mistyshell
Alabama
Ford ranger
Help me please will a electronic module from a 94 fit a 95 ford ranger
Colin
182
ON Canada
Mazda
Probably be easier to help you if you specified which module
89Twincharge
182
Turbo coupe transmission work on 2.3 rangers with a simple trans bracket and mods to the clutch line(adapt to external slave cylinder)...
Saxwing1988
9
spokane
Ford ranger
3” with torsion crank
33x12.5
I did a 2004 front end and it bolted on my 99 no problem. I also did the seats to but the mountings different
JohnAllen
7
Woodstock, GA
Ford Bronco2
6"
33x10.50r15
Ok..........
I have built 2 gen 3's (93 & 94) and am workin on 2 more (94 & 95), so I will tell what I have found within these builds, but if you need to know other info, I have the ability to check via Ford catalogin at work:
93-97 fenders, hood, front bumper, grill, headlights, marker lights are a direct swap.
93-94 radiator supports are same and 95-97 are same (2 different PN's)
93-97 doors interchange
93 to 08 beds are direct bolt ons and taillights are interchangeable
92-02 Explorer rearends are direct bolt-in if you want 4" of drop in the rear, if don't want the drop, then you have to weld on new leaf spring perches
92-02 Explorer seats will bolt right in after you swap the Ranger tracks to them, the Explorer seats have the holes made into them for the tracks
93-97 cabs are interchangeable, as are 98 up
82-97 steerin boxes are interchangeable to include the MS boxes
82-94 heater boxes interchange, as does 95-97
I'm sure I'll think of more, but that's all I can think of for now!:icon_confused:
Do you know if the power steering pump will interchange from an 89 to 95 if I use the hoses for the 89?
Maui-sprint
65
Oahu, Hawaii
Are 1st and 2nd gen hoods interchangable? I'm concerned the front lip may not align...
Have opportunity on a "squarebody" hood but unsure what year it was from. The truck I want to use it on it an '89.
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
No... not without swapping the entire nose.
