your rear tires would rub
I can clear it for that....
Mud raaaaaaiiiilllllllllllllll!
Hell yeah!!
Alright, on a serious note(more for me to help me remember), did some measuring for body mounts, if I go no body lift, my rear mount will be located about 1" to 2" from the bottom of the frame rail, using stock bushings. The rear stock bushing is 2" tall, so I can cut that down to 1" to raise it up a bit. I ended up figuring it all out using a 1" body lift, with the rear mount raised up to use only a 1" bushing, I can raise up the mount 2" to get some more frame the attatch the mount. with the 1" spacer it puts me about 2.5" from the top of the frame. Basically this is telling me I have to channel my floor 3.5 " with a 1" bodylift. I wanna run no body lift, but 1" isn't too bad.
Another thing, I have to move my gas tank into my bed, other wise the fill would be under the cab...gives me less to worry about anyway, no tank to smash on the ground.
