RangerDan99
- Dec 4, 2010
- Reaction score
- 1
- Location
- northeast, Ohio
- Make / Model
- Ford
- Engine Size
- 4 liter V6
- Manual
yeah i got pictures i will add them after work today
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Like you said they don't flex enough for a buggy. Hence what I am saying coils and coilovers are better. Leafs can flex well, but they cannot flex as well as a correctly setup coil/coilover. I have a great flexing set of rear leafs on my XJ has ton's of up and down travel, but it is nothing compared to the up and down travel the front has with its correctly set up 4 link.I would argue that the right leafs and the right setup will flex as much as needed if you're not doing some crazy buggy build.
I helped do a leaf spring build on a YJ a few years ago, it got a surprising amount of flex (took a little experimenting with spring packs to get it right, but it comes with the territory). We ended up doing a 3/4 elliptical in the rear while we were at it. It actually flexed better than my choptop that is running coils up front and leafs out the back.
To go to coil overs would take just as much fab work as leafs. Going with a stock diameter coil is were the time saving/money savings is.That said.... for the OP, I would lean towards using coils or coilover/air shocks simply because the axle is most likely set up for coils and if you decided to go with something different, why convert the axle to leaf springs....
I have a 98+ IFS rig as well. I vote coils **** simplicity it will perform betterconsidering he has a 98+ IFS truck.....any SAS is gonna be alot of fab work....but in this case leaves would be easier....
plus, he never mentioned he was goin for a buggy anyways....
l8r, John
Depends pretty easy to check if its 5 on 4.5" its a D30. 5 on 5" can be as well but they are a little more rare and just as strong as an EB D44.Sounds to me that you need to post them pictures to see if maybe it is a Dana 30 and not a 44.
I have YJ leafs on my Ranger....they flex real good. I did add a leaf to help with the weight of the 4.0 and the A4LD. Hasn't sagged yet.I would argue that the right leafs and the right setup will flex as much as needed if you're not doing some crazy buggy build.
If it is a Dana 30 from an early bronco it will be 5 on 5.5 not the 5 on 4.5.Depends pretty easy to check if its 5 on 4.5" its a D30. 5 on 5" can be as well but they are a little more rare and just as strong as an EB D44.
I thought the Bronco was a D27 or 28 not a 30? The D30 I was referring to in my post was a JK D30 with 5-760x joints and the bigger ujoints.If it is a Dana 30 from an early bronco it will be 5 on 5.5 not the 5 on 4.5.
the jk dana30 is not as strong as the eb44 in stock form.. but the aftermarket support for them is HUGE. the jk dana30 is a slightly glorified d30, period.I thought the Bronco was a D27 or 28 not a 30? The D30 I was referring to in my post was a JK D30 with 5-760x joints and the bigger ujoints.
So you are saying the eb d44 with its little bitty 5-260x joints crappy shafts is weaker than an axle known to be good with 35s pretty much stock and 37s with shafts a truss and reinforced C's?the jk dana30 is not as strong as the eb44 in stock form.. but the aftermarket support for them is HUGE. the jk dana30 is a slightly glorified d30, period.
wait sorry. wrong axle.So you are saying the eb d44 with its little bitty 5-260x joints crappy shafts is weaker than an axle known to be good with 35s pretty much stock and 37s with shafts a truss and reinforced C's?
The EB D44 is a terrible D44 in stock form it is not stronger than a 90s XJ axle. There is however a lot offered for them.
