dhinch279
- Feb 20, 2009
- 44
- DeSoto, MO
- Ford
- Engine Size
- 4.0
MORE PROGRESS:
Well I got the passenger side coil spring in, I had to use a spring compressor just to get it in, but its in!
I would have went ahead and put both sides in but I am having some trouble getting the Pitman Arm off.
I have soaked it in PB blaster for 2 days, and I rented a 3 different kinds of Pitman arm pullers, and nothing has the kahonas to get it off (including me and a baby sledge). Am I doing something wrong?
Here is the Stubborn thing:
Ladies and Gentleman, Step right up to see the $20 bolt from the one and only Ford Stealership. And we must not forget it's Companion the $3.50 nut. (and you have to buy the bolts in pairs and the nuts in packs of 4). Mine were so rusty that it strip the threads on the way out.
Well, another snag I ran into was the brake lines. I let them soak in PB Blaster for a day or so, grabbed my 7/16 wrench and got to work slowly. The drivers side broke free and was coming along just as it should... THEN DISASTER, I noticed a drip...drip. Look around and about 6-8 inches back on the line I must have disturbed a very weak spot and a small pinhole appeared. Then the rest of the lines broke, so now I get to put in all new brake lines up front... yay But at least I got them off and the new extended brake lines on the calipers.
At least I get to end it on a somewhat good night, I got the coil spring in and got all the wheel bearings packed and in ready to put back on. Progress is slow, but steady
