Looking for audio electrical gurus...
masanders
36
Greenville, SC
2.5 (4 Cylinder)
2.5L
Don't get louder, improve your argument.
Hey folks!
I'm having an issue with my Sound Ordinance 8BPTD http://www.crutchfield.com/p_777B8PTD/Sound-Ordnance-B-8PTD-Powered-8-Subwoofer.html thumping/popping when the Kenwood KDC-BT365U radio http://www.crutchfield.com/p_113BT365U/Kenwood-KDC-BT365U-CD-Receiver.html is turned on and turned off. Everything is hooked up using a Rockford Fosgate amp kit http://www.crutchfield.com/p_575RFK101/Rockford-Fosgate-RFK10i-10ga-Amplifier-Wiring-Kit-w-RCA.html .
I followed all wiring instructions, did the ground right, using the RCA cable...but there is still that darn popping.
I tried a time delay (NE555 based) circuit, tried a homemade 12v - 5v voltage reducer that was more of a lesson in soldering, and tried different voltage inputs with no success on all fronts. I know I can can Crutchfield and talk to tech support, but i think that'll be a last resort.
Got any ideas?
8,372
That's just the sub doing what it is suppose to do, amplifying sound that comes to it, it isn't a ground or wiring issue.
Problem is either in the radio or amp and while not good it is "normal".
Many radios and amps have a "mute" relay/circuit on the output, when you power up or power down an electric circuit it will make some noise, the mute relay prevents that noise from going out to the speakers, because of the wattage this noise is more noticeable on subs.
If you have a powered sub, built-in amp, then turn it on and off manually, if it pops then problem is in that built-in amp, powered subs usually have the mute relay, so call manufacturer and ask about it.
If sub and amp are separate then do the same thing but just power on sub amp only and power off
If powering on and off the sub manually doesn't have the pops then it does have the mute relay.
The "pop" is coming from another component, you can just power on sub a few seconds after other components, and power off sub before other components are powered off.
Or replace other component with one that has the mute relay/circuit.
EDIT:
I thought of one thing that might come up, the mute relay/circuit is part of the power on and off "button" on the devices, i.e. when you power on the radio/amp with the button it opens the relay, then powers the radio/amp, then closes relay, when you power off the radio/amp with the button it opens relay first then powers off radio/amp.
If you are not using the on/off button just leaving it on and powering the system with key on/off then you are eliminating the mute circuit.
Mazda
11
Temecula, CA
Mazda
2.3
Everything that RonD says +
I see that you are referencing Crutchfield item numbers and web pages. Are these just for our benefit or did you actually buy the item from Crutchfield. Oh I see that you did.
If so they offer one of the best lifetime customer service departments that I have ever had the pleasure to deal with. Give them a call, sometimes depending on the head unit they can tell you how to turn on/off a function that is not listed in the manual.
masanders
36
Greenville, SC
2.5 (4 Cylinder)
2.5L
Yes. I bought them.
