Looking to upgrade to a bigger tire for my rims if possible. 1993 Ranger XLT SC
Angry Possum
No Fat Chicks, Truck Will Scrape
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
Sometimes you eat the bear, sometimes the bear eats you.
I currently have 235/75/15 tires on my stock 1993 Ranger XLT SC Rims. What larger tires can I upgrade to without changing the stock rims. I'd like a wider and taller tire if possible.
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Angry Possum
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
Angry Possum
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
Angry Possum
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
I found them, thanks.
Angry Possum
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
@Uncle Gump The ones I'm interested in are on Amazon, it says it's only capable of handling 2271 lbs. My Ranger is 4800 lbs. Will these still work?
RED DIRT ROAD TIRE 31X10.5R15LT 109Q 6PR MT RD-8 https://a.co/d/i0jyuiX
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Those are 6 ply light truck tires... they'll be fine.
Those will be noisey and probably best suited for off roading.
If you do most driving on road... you would be better off looking at more of an All Terrain tread.
ericbphoto
16,598
Wellford, SC
6"
Like Uncle Gump said, they'll be fine.
4800kb Ranger divided by 4 tires would be 1200lbs per tire, if evenly distributed. That leaves 1071 lbs of cargo weight per rear tire. But the Ranger's weight will be based toward the front. So there is even more capacity available on the rear tires. Way more than the gvw for the vehicle. The axle and springs may actually be rated for a bit less than those tires. So the tires are fine.
BroncLander
412
BC Canada
XLS Bronco II
I have 31x10.5 R15 mudders and they howl so loud on the hwy. I just turn the music up.
The best off road tire for least road noise Ive ever had are BFG K02s
00t444e
217
Southern OH
Ranger ext cab
BFG KO2s are terrible off road tires. I have them on my ranger currently and they are awful. Going to sell and get some real tires for it soon.
Josh B
1,986
Oklahoma
My 93 had 265/75r15SL from the factory
When they wore out I put 235s on it that decreased their size by 7% according to Michelin tire calculator.
Ten miles on the turnpike verified that number, so I guess if you were going back the same direction it would add 7%
I take that back, actually it would need to be calculated from the other direction so I guess you'll need to ask michelin
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
ericbphoto
16,598
Wellford, SC
6"
Tire treads are very controversial. Anything marketed as "all terrain" will be somewhat good in many scenarios and really good at nothing. I, personally have had good results with BFG KO2's. But I prefer the KM3's that are marketed as "mud terrain". They are my go to Tire. But... I travel primarily in the eastern US. They work well in most muds I encounter, they give me decent grip for climbing rocks and they work nicely on gravel and common dirt roads. They can get you through loose sand, but that is not their strong point, in my opinion. They do ok in snow. But I don't get a lot of snow.
My point is, you need to choose tread and Tire composition for the areas you will be traveling. The guys that run in deserts out west prefer different tires from what works well in the east. But they have more sand, different mud and different types of rock. So they have different needs for tread design and rubber composition - whether it's soft and sticky or harder. Soft, sticky tires will wear quickly on the road. There are trade-offs in choosing tires, unless you can afford a different set for each terrain you encounter. One person will say a tire is garbage and the next guy will love that Tire. Be careful about opinions. There is a park in Tennessee called Wind Rock, that is over 72,000 acres. It has several different types of rock and several types of soil and mud. A Tire that works well in one part of Wind Rock may not be the best for another part. You pick the best you can and work with what you have.
BroncLander
412
BC Canada
XLS Bronco II
I was running some Goodyear Duratracs on my Jeep and I would buy them again because I never got stuck even once with them. And I'm in Northern BC
