Lower Intake Bolt Retorque
JerrySab
44
Los Angeles
Hey gang,
I'm in the process of closing out the latest project, which included new head and intake gaskets. The excellent write-up i followed, said to apply black silicone to bolt heads and stud nuts of the lower intake. Which i did. Last step would be retorquing the intake bolts after engine is warmed up. I just retimed the motor, and now that everything is warmed up I'm heading back in to retorque everything, and I'm not sure if I should touch the lower intake bolts. Wouldn't that disturb the silicon on the bolts? I definitely want things appropriately snug but I'm nervous i'll disturb a seal and need to go spelunking again. Which I don't want. Appreciate your thoughts.
gaz
657
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
@JerrySab ,
- black silicone RTV is not required on the bolt heads
- because it's not required, retorquing them will not change the affect of the RTV
JerrySab
44
Los Angeles
Thanks @gaz torqued these back up. can't believe how much they loosened up. That back one by the distributor was a PITA.
No members online now.
