M5od-r1
ianalex
Does any one what the torque rating is for the M5OD-R1 transmission. Second, Does the M5OD-R2 have the same bolt pattern as the M5OD-R1 so I can bolt it up to my 3.0.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
The R2 is from the full size trucks and will not bolt up to your 3.0L.
Also, you need an M5OD R1 from a 3.0L, and only a 3.0L as it has its own bell housing bolt pattern.
ianalex
Thanks for the info, by any chance do u know what the torque rating is for the m50d-r1
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
people run them behind 150hp 4.0L's with good success, and are ran in 300hp 2.3L turbo trucks without much issue. I don't know what they are rated for. keep fluid in them (the shift rail plugs are known to leak at times)
