Manual brakes
Northidahotrailblazer
457
Northern Idaho
Solid Axle Swap 4x4
8 inches
37"
I searched and searched for info on the g30 or the astrovan hydro boost, I couldn't find any solid info on what would work. after all this, a belt driven 7.3 vacuum pump would of been cheap. lol I guess I just live and learn I guess. 🙃 What not to do.....
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
i run the g30......its a bolt on too.
all you have to do is drill some holes on some plate.....weld it to a scrap piece of 2 inch pipe nipple after figuring some angles out....and bolt it on.
then figure out the pedal ratio and rod travel so it dont side load it.......
and get some of those adapter doo dads.....
and bleed the fawk out of it .....and blow some lines....and bleed the fawk out of it some more.....
and it works mostly....
