Maybe boosting a 2.5
YungICY
2.3
I’m looking into possibly boosting the 2.5l I have in my 85 ranger. I’ve never boosted anything before so I’m looking to have a couple questions answered before I start to open a can of worms I don’t want to.
The goal here is to go with a low boost setup (~5psi) to get those few extra ponies I need from time to time.
Current setup is an 85 ranger prerunner with a stock 2.5l out of a 99 ranger running on the stock 99 eecv I don’t recall the fuel pump specs off the top of my head but it’s an aeromotive stealth series pump with an aeromotive style knock off regulator.
Can I boost this 2.5 without doing any other mods and have it run correctly. I imagine I may need different injectors but I’m more concerned about if the stock eec with be able to compensate and maintain a low boost application.
Throw some knowledge at me. If it can be done as I’ve described, what parts would need to be changed out, (injectors, maf etc)?
Thank you.
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I don't know enough to give you any helpful tips but there has been a few that have 2.3 Lima engines that have turbos or they installed turbos on them. The 2.5 Lima is either a bored or stroked 2.3 Lima (I can't remember which). So, whatever works with them should work with the 2.5. Some parts made for a 2.3 will fit on a 2.5 as well. It might be worth your while to check out some of those threads.
YungICY
2.3
I have a buddy with a turbo setup he’ll let go for cheap so I’d really just need the manifold to bolt it on which I believe the 2.3 and 2.5 are the same there. I just don’t want to have to go down the tuning/ecu road as that’s out of my wheel house. But if the stock eec will reliably compensate for low boost and I maybe have to change a few parts out that makes it much more approachable and financially effective for me to squeeze another maybe 30 or 40 horse out of her. Otherwise the option is to do a full turbo build and then it just makes more financial sense to put in a 302 or even a junkyard gm 4.3.
sgtsandman
12,651
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
I believe you are correct on the intake manifold.
As far as the rest, I'll have to refer you to any threads involving installing a turbo on their 2 3, 2.5, or installing an already turbo equipped engine from another Ford vehicle.
Hopefully, one or some of the people who did it are still active and can provide some insight. I don't know of any off hand in order to tag them and highlight your post.
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
The 2.5 uses the same exhaust flange as the other Lima's so that part is fine.
The main drawback to the 2.5 is the Hypereutectic pistons and powder metal rods that are lighter built than the standard Lima stuff... that said if you stick to the 5psi limit with a wastegate controller of some form (from what I hear blowoff valves and MAF engines don't mix well) and go with one size bigger injectors you will likely be ok
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Blowoff valves serve a different purpose than a wastegate, but aren't exactly necessary. A 100% recirc valve would be ideal for a MAF setup.. but running a BOV shouldn't cause actual problems. youd get some super amusing *pop-crackle-bang*s while shifting and a bit of soot on the body around the exhaust as a byproduct of said extra noise.. but thats about it on a reasonable tune. I ran an adjustable BOV on my old outback.. had it set to dump about 25% to atmosphere and recirc the rest. Gave me a good balance of WHOOSH and exhaust crackles without any discernable soot on the bumper or dogginess when getting back into the throttle.
Whenever I get around to putting turbos on something else I'm not gonna bother with a recirc/bov at all.. as I'll always be a child at heart and compressor surge sounds AWESOME!!!
