My 1995 Ford Ranger XLT wont stop squeeking!!!
bps61611
As the title says my 1995 Ford Ranger XLT wont stop making a squeaking noise. When I break, and drive casually this loud squeek wont stop. I was looking under the truck and I noticed these things which may be the problem (fyi I just patched my exhaust and a liquid is leaking from it). Need help ASAP!
See pictures! THANKS!!!
black_demon69
142
AZ
4.0l
could it be a brake squeek?
huh?
hawaii
lay under the back of the truck and bench press the rear bumper up and down till you can pinpoint the squeek source.
That'.
Its probably a dry bushing or bad shock valve.
pintobobster
Washington State
FORD
squeeking
check spare tire that was my noise, took me awhile to find it too
rangerin
North Carolina
2.8
I had a bad squeak once. It ended up being a e-brake cable (before the Y slpit). Shot some PB blaster on it and after a bit it went away. Gosh that drove me nuts haha
AgPete139
09/2014 OTOTM Winner
61
Houston, TX
4.0L OHV
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
lay under the back of the truck and bench press the rear bumper up and down...
Cheater. The weight of the truck is supported by the wheels. You'll never get to the Crossfit Championship that way... :bawling:
