My #3 spark plug keeps fouling. What do i do?
mb3offroadr
i have a 99 ranger 4.0 and in the last year i have fouled my #3 spark plug about 3 times. any ideas on what could be causing this?
thanks in advance
mat
Sevensecondsuv
7
Northern IL
Many
All Fords!
Many
Bad fuel injector maybe.
Bob Ayers
16
Durham, NC
Bad plug wire, bad valve guide seals, or bad rings.
Will
514
Gnaw Bone, Indiana
Toyota
Doubtful on the rings or stem seal being as it is just one cylinder. Wire or injector are a good start.
shadetree
9
East Texas
Explorer Sport
How is it fouling? Is it carboned up, caked with white stuff, or just not working?:)shady
Evan
5
Stevens Point, WI
4.0 OHV
If the injector is sticking in the open position, it will foul the plug. That happened to me on #4.
If you have a leaky valve guide on the intake or exhaust port for that cylinder, you will end up with a fouled plug.
I would guess it's one of the above that's causing your plug to foul.
dieseltweaker
Pennsylvania
mine kept doing that and i had had a small leak in my head gasket and it eventually blew out.
UrbanRedneckKid
17
Cass Co, Missouri
Mine's doin the same thing. when i put the engine(used) in I did a tune up on it. #3 was fouled and had traces of oil on it. I'm thinkin it's a stem seal, cause I have a little poof of smoke when I first start it up.
Can you give anymore details about yours?? How does the plug look?
Danger06Ranger
Lowell, IN
Ford/Mercury
4.0L/351M/2.5L
:worthless:
Seriously, they might help.
MikeMcC
Guys if this is the 4.0 OHV It's extremely likely you have a cracked head or blown head gasket. This is a common problem on all 4.0 OHV's. The tale tell sign is if you are getting a little bit of white smoke on start up.
If would recommend a compression test. You will probably have low compression on the cylinder that keeps fouling plugs.
If replacing the plug fixes the problem for a short time but it comes back, you know it's nothing ignition related, and it's something thats actually fouling the plug. In this case It's almost a 100% certainty that you have a blown gasket/cracked head.
Ways to check for a blown head gasket/cracked head:
1. Slowly loosing coolant.
2. Smoke at start up.
3. Rough Idle.
4. Fouling spark plugs on a regular basis.
5. Inspect the block for coolant leaks around the heads, and pull the spark plugs after they have been sitting for a while to inspect for coolant.
6. Check for coolant for presence of oil.
7. Send your oil off for a used oil analysis. If it comes back with coolant contamination it's most likely a head/gasket.
If it matters I also have a 99' 4.0L that was fouling on #3. Turned out to be a cracked head.
UrbanRedneckKid
17
Cass Co, Missouri
Don't tell me that. Who wants to hear that??
Sad, but very true. These heads are REALLY known for cracks.
Fortunately for me and I already properly diagnosed mine. Mines not a headgasket/ head prob.
No members online now.
